I have several lanes and child lanes in one pool, but now I find that the pool is obsolete and the parent lanes should be pools. Is there an possibility to do so easily?
Otherwise I have to build this structure anew an merge the lanes. But can I merge the parent lanes with their then new equivalent - a pool?
I would be glad to get to know a good solution for me working at the client version.
We are sorry that at this moment no simple solution for your case.
It is possible to achieve but complex and hard.
We planned to support your case.
However, it is better to have your project file to ensure our enhancement works in your case.
If possible, please send it to: support-team@visual-paradigm.com
and include the link to this post in the email.
Regarding to your case you can right click on the lane and select Related Elements > Change Type to change it into Pool. After changing the lane into pool you can drag it out form the original pool to become an independent pool on the diagram. Please note that you will need to resize the original pool a bit to make it auto fix its size for the removed lane.
BTW we had made a small enhancement on latest v15.1 on changing lane into pool and you can update the software to latest patch build (20181030aj or later) to get this enhancement. Details about update to latest patch can be found at
Feel free to contact me for any questions and wish you have a good day!
@jck Could you please double check that if you open the Help tab and then click About that it mentions 20181030aj in the lower right corner?
Also: I seem to vaguely recall this feature not to appear on the very first time I right clicked on the lane, but I could be mistaken. Try to de-select the pool (or lane) by clicking on canvas somewhere (once) and then hover the mouse over the lane again and right click.
But could it happen (after seeing your Screenshot), that working on a Mac might be the reason? I tried several variations of clicking/selecting and de-selecting. This “Change Type” doesn’t want to appear.
I can’t rule this out simply because I don’t know, but it seems unlikely to me. See: Visual Paradigm is developed in Java which means that besides a few specific components such as the launcher and the installer everything else should be the same on all platforms.
There’s one thing you could try: create a new project, add a new BPMN diagram and then add a pool with one or two lanes. Then try this procedure again (right click on the lane).
If that also doesn’t show this option then I’m running out of ideas.
