I’m trying to install VP on windows server 2012 R.
when i’d tried to run install_service.bat i get the message below. I have already tried the solutions proposed in the previous topics. can you please give me a hand.
Best regards.
Installing the service ‘VPServer’ …
Using CATALINA_HOME: “C:\Users\ab.bennis\Desktop\VP_Server_15_0_20180404_Win6
4\VPServer\webserver”
Using CATALINA_BASE: “C:\Users\ab.bennis\Desktop\VP_Server_15_0_20180404_Win6
Using JAVA_HOME: “”
Using JRE_HOME: “C:\Users\ab.bennis\Desktop\VP_Server_15_0_20180404_Win6
4\VPServer\webserver\bin…\jre”
Using JVM: “C:\Users\ab.bennis\Desktop\VP_Server_15_0_20180404_Win6
4\VPServer\webserver\bin…\jre\bin\server\jvm.dll”
Failed installing ‘VPServer’ service
Press any key to continue . . .
I tested with Windows server 2012. I got a little problem but different from yours.
Then I tried run command prompt as administrator and problem solved.
And I found the path in your log is wrong: “bin…\jre”
Are you running the script in “C:\Users\ab.bennis\Desktop\VP_Server_15_0_20180404_Win6
4\VPServer\scripts” folder?
First of all, thank you for your time and i’m sorry for the response latency.
for your remark: "
4\VPServer\scripts” folder? "
I run the install service using administrator acesse from the script folder. I noted also that after i run install_service.bat the path changes in the cmd prompt (see the image below).
Would you mind try to install tomcat service to identity whether it is a general install service problem in your windows, or specific problem of VPServer?
