Greetings,
I think this happened after 12.2 update. This worked back in June. When I start visual paradigm debugging session I now get a crash caused by jxbrowser.
Here is full message:
/usr/lib/jvm/java-7-jdk/bin/java -agentlib:jdwp=transport=dt_socket,address=127.0.0.1:46248,suspend=y,server=n -Dfile.encoding=US-ASCII -classpath /usr/lib/jvm/java-7-jdk/jre/lib/rt.jar:/usr/lib/jvm/java-7-jdk/jre/lib/javaws.jar:/usr/lib/jvm/java-7-jdk/jre/lib/charsets.jar:/usr/lib/jvm/java-7-jdk/jre/lib/jfxrt.jar:/usr/lib/jvm/java-7-jdk/jre/lib/jce.jar:/usr/lib/jvm/java-7-jdk/jre/lib/plugin.jar:/usr/lib/jvm/java-7-jdk/jre/lib/deploy.jar:/usr/lib/jvm/java-7-jdk/jre/lib/jsse.jar:/usr/lib/jvm/java-7-jdk/jre/lib/management-agent.jar:/usr/lib/jvm/java-7-jdk/jre/lib/jfr.jar:/usr/lib/jvm/java-7-jdk/jre/lib/resources.jar:/usr/lib/jvm/java-7-jdk/jre/lib/ext/dnsns.jar:/usr/lib/jvm/java-7-jdk/jre/lib/ext/sunec.jar:/usr/lib/jvm/java-7-jdk/jre/lib/ext/sunjce_provider.jar:/usr/lib/jvm/java-7-jdk/jre/lib/ext/localedata.jar:/usr/lib/jvm/java-7-jdk/jre/lib/ext/sunpkcs11.jar:/usr/lib/jvm/java-7-jdk/jre/lib/ext/zipfs.jar:/opt/VisualParadigm/12/plugins/sample.genflowofevents/classes:/opt/VisualParadigm/12/lib/vpplatform.jar:/opt/VisualParadigm/12/lib/jniwrap.jar:/opt/VisualParadigm/12/lib/winpack.jar:/opt/VisualParadigm/12/lib/openapi.jar:/opt/VisualParadigm/12/lib/lib01.jar:/opt/VisualParadigm/12/lib/lib02.jar:/opt/VisualParadigm/12/lib/lib03.jar:/opt/VisualParadigm/12/lib/lib04.jar:/opt/VisualParadigm/12/lib/lib05.jar:/opt/VisualParadigm/12/lib/lib06.jar:/opt/VisualParadigm/12/lib/lib07.jar:/opt/VisualParadigm/12/ormlib/orm.jar:/home/fai/apps/Intellij-Idea-14.1.5/lib/idea_rt.jar RV debug
Connected to the target VM, address: '127.0.0.1:46248', transport: 'socket'
[Sat Oct 10 12:07:22 EDT 2015]: Start Visual Paradigm Professional Edition [VP PE]: 12.2 (20151001)
Operating system: Linux 4.2.2-1-ARCH running on amd64
Java VM: 1.7.0_80 Java HotSpot(TM) 64-Bit Server VM, vendor 24.80-b11 Oracle Corporation
User: fai, language: en
Installation ID: c86320c0e897f53b6ce3d21433c4130b
Memory: current=361M, max=5356M
Refreshing language files in directory: /opt/VisualParadigm/12/bin/../UserLanguage
start startup getLicenseKey on 10-Oct-2015
getLicenseKey in local ...
getLicenseKey from server ...
finish startup getLicenseKey
getVerifiedLicenseKey: null; state=Evaluating
Installation properties: /opt/VisualParadigm/12/resources/vp/.vpsuite_installation.properties
Workspace: /home/fai/vpworkspace
UI mode: Classic
New Project: 40
Load application project: /home/fai/vpworkspace/.vpprefdata/.systemproject.vpp
New Project: 16
After open: : 124
---------- new TWClient ----------
New Project: 636
Exception in thread "Thread-2" java.lang.NoClassDefFoundError: com/teamdev/jxbrowser/chromium/ProxyConfig
at v.zii.af(:1534)
at v.zii.r(:1283)
at v.zwt.<init>(:4674)
at v.aauf.b(:345)
at v.aauf.a(:51)
at v.aaug.run(:164)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.ClassNotFoundException: com.teamdev.jxbrowser.chromium.ProxyConfig
at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
I tried looking through VP lib folder to see if its some obvious jar file I have to add to lib path but could not find any. What I am doing wrong? Thanks.
