General Modeling
Fixed merge classes prompt user to delete attribute linked with association
Fixed property stereotype incorrectly applied to operations
Fixed gate caption put too far away from gate when opening interaction use the first time
Fixed “Never delete model elements” with referenced views
Ignored quality information when comparing diagrams in Visual Diff
Impact Analysis
Fixed code cannot be appended to chart cells
Interoperability
Fixed mispositioned operand separator after importing XML to new project
Fixed import XML cause project option’s default HTML font size become 0
[Report Generation]
Fixed tooltip for nameless association in published outcome shows null:Association
Fixed bad project publisher outcome due caused by the entering of working procedure in BPD
Fixed unable to drag and drop template to report in report composer
Fixed unable to show value of HTML tag in report composer
Fixed report composer failed to handle non-Eng characters properly for templates
VP Server
Fixed nameless user role available for selection in VP Server
General Modeling
Fixed some exceptions that may throw when saving project
Fixed null pointer exception when try to change color/font in Text Box
Fixed a StackOverFlow error that may happen when saving project
Fixed failure in converting operands from project saved under VP Suite version 5
Fixed broken list in documentation editor caused by inserting point break in list
Fixed class’s ownership be controlled by auxiliary view by creating containment
Supported resizing ports (attached to component) towards all directions
Enterprise Architect
Removed decision model support
Report Development
Fixed unable to hide element type selection in report template
Fixed unable to generate images with project publisher
Code Engineering
Fixed the ‘use’ of namespace in PHP 5.3 is not reversed as relationship via Instant Reverse
Process Engineering
Fixed error while generating BPEL
Use Case Flow of Events
Improved the layout of activity diagram synchronized from use case flow of events
Object Relational Mapping/Hibernate
Supported returning list of objects in ORM, in addition to returning array of objects
Project Referencing
Fixed saving current project cause project data of referenced project lost if the project is referenced by another referencing project and is removed from current project
Fixed saving current project saves referenced project even without modification
VP Server
Supported downloading 64bit installer in VP Server ‘Download Installer’ page
Miscellaneous
Fixed the About window wrongly shows expiry information even run with purchased license key
General Modeling
Fixed diagram flash when dragging and dropping shape to diagram
Fixed incorrect vertical position of lifeline when reattaching the end of message flow
Fixed open project prompts for resolving referenced project again and again
Fixed missing function to set shape’s background color as default
Fixed undo duplicate shape not remove model element from Model Explorer
Supported tagged value specification
Report Development
Fixed grid content show in report composer failed to wrap
Fixed tables with wrong repeating headers in report composer
Fixed incorrect font size for Word report exported from report composer
Fixed report composer split the title and image below title
Supported importing styles to report composer from MS Word
Added report templates for report in report composer
Code Engineering
Fixed exception throw when update model to C++
Improved the layout of activity diagram synchronized from flow of events
Fixed connection provider class default empty for MySql ORM
Fixed missing InnoDB for PHP
Team Collaboration
Fixed unable to commit project if the last revision was about committing a teamwork file and was done in previous month
General Modeling
Fixed unable to change the ID of business rule when change via rule editor
Fixed unable to use format copier to copy format from model shape to class shape
Fixed project is still marked modified after fixed
Fixed Simulacian panel does not show the name of sequence flow properly
Fixed unable to transit from conceptual to physical ERD (case specific)
Fixed element visualization allows visualizing to only one diagram type (should allow all)
Fixed slow project opening
Fixed incorrect option window is opened when trying to configure ERD index name pattern
Fixed trimmed label after resizing
Improved application performance a little bit
Report Development
Fixed duplicated constraints show in Word report
Fixed several translation issues in publisher outcome
Project Referencing
Fixed removing referenced project wrongly removes use case in current project (case specific)
Improved “Failed to mirror” warning message to display the problem area
Fixed auto save wrongly modifies referenced project files
Code Engineering
Fixed unable to reverse a PHP file via instant reverse
Fixed relationship is missing when reverse C++ code via round-trip
Fixed ORM wizard does not work properly
Team Collaboration
Fixed enhancing VPServer Update Module to support resuming failed update
Renamed menus to differentiate Revert Local and Revert Revisions
Open API
Fixed class generation problem when generate via API when dealing with referenced project
Supported exporting project to simple/traditional XML when export via command line
General Modeling
Fixed term editor content lost when closing editor (for VP-UML and SDE Standard Edition only)
Fixed pressing up and down when inline-editing entity column failed to move the column selection up and down
Supported sub-bullet points in RTF documentation
Supported manually creating transit from and to on models between referenced projects
Report Development
Improved the presentation of working procedure in published outcome
Fixed heading lost when refreshing TOC in Word report exported from report composer
Interoperability
Fixed XML exporting wrongly included diagram images even with the export option unchecked
Fixed missing column domain when exporting ERD to Excel
Fixed export XML missing chart’s content and code type
Code Engineering
Fixed six issues related to C++ code generation (via round-trip)
Grid
Fixed unable to undo deleting sub-process from grid
Fixed deleted element remain visible in grid
Added five Hibernate connector provider class selection for database generation
Fixed unable to generate DDL due to problem in sequence
Fixed improper “lazy” in .NET ORM mapping file
Business Process Modeling/BPMN
Fixed “show lane” makes the diagram content bad
Fixed freehand text box cannot be contained by BPMN lane
Miscellaneous
Supported opening project file by dragging and dropping file to the application
General Modeling
Fixed unable to resize data object caption if the data object is put inside pool
Improved stereotype popup menu to list only stereotypes in-used
Product/Policy
Merged editions for DB Visual ARCHITECT
Report Development
Fixed bad list is presented in generated PDF report caused by HTML documentation
Fixed Word report exported from report composer failed to apply proper diagram image size
Fixed Word report exported from report composer failed to show diagram and header on same page
Fixed unnecessary line break in Word report exported from report composer, for working procedure step
Fixed “always show indicators” does not work in publisher outcome
Fixed missing highlight for textual analysis in report composer
Impact Analysis
Fixed unable to remove RACI chart in Agilian Standard Edition
Fixed bad layout of chart diagram
Team Collaboration
Fixed partial commit diagram does not commit diagram lock
Interoperability
Fixed exported XMI file being locked (not deletable)
Fixed export and import stereotype failed to handle images added to stereotype as icons
Code Generation
Fixed enum not generate as xs:enumeration in Instant Generator
Fixed multiple named queries in ORM generate invalid code when using JPA
Fixed the progress of diagram generation by walking through wizard failed to reach 100%
Product/Policy
Fixed failed to switch between editions of VP-UML when installed DB-VA
General Modeling
Fixed freehand text disappear during editing in BPMN lane
Fixed unable to create new glossary term via Model Explorer
Fixed property pane allows naming a diagram with existing name
Fixed unable to zoom locked diagram
Fixed Eclipse integration hang in Mac
Fixed select in tree not working
Supported more specific tagged value show/hide options
Supported showing diagram name in view shape in analysis diagram
Added presentation options for showing/hiding the role names and arrow heads for associations specified for links in object diagram
Automatically parse classifier when editing instance specifications’ names inline
Report Development
Fixed unexpected blank lines after element documentation in report exported from report composer
Fixed unexpected line break produced in report exported from report composer
Fixed unable to export HTML report from report composer
Fixed reference indicator does not show up to message and sequence flow in published output
Fixed report generation for template wrongly reads an option set for non-template way of generation
Fixed Word report generation missing line breaks for title text
Fixed report template editor failed to show line breaks for title text in preview
Report composer template supported @ignoreParagraphBreakForLastModel in ForEachDiagram for removing last page break, paragraph break
Hibernate/Object Relational Mapping
Fixed DAO classes are generated when trying to generate POJO
Interoperability
Fixed exported XML missing stereotype of attributes and operations of class
Fixed import BPMN throws exception
Code Engineering
Fixed C++ round-trip engineering failed to handle namespace
Supported diamond operator for instant reverse of Java7
General Modeling
Fixed mis-placed popup menu in Format Fill Color window when work with multiple displays
Fixed ID is missing for requirements created by the ‘Create Model Element’ function
Fixed unable to apply the change of color from solid to gradient
Supported creating lanes in same pool by dragging organization units to BPD
Improved performance for “Close All Diagrams”
Team Collaboration
Fixed renaming user group in Teamwork Server can set a name used by another group
Fixed performing full commit after reverting changes after a partial comment result in error
Automatically filled ‘root’ as the user of MySQL for screens that require MySQL connection
Database Engineering
Supported reversing comment when reversing SQL DDL
Fixed missing schema when reversing database from SQL Server (case specific)
Interoperability
Fixed export stereotype XML missing some of the images defined to stereotypes
Code Engineering
Fixed Instant Generator generating incorrect minOccurs and maxOccurs for XSD
Fixed a failure in reversing Python (case specific)
Supported ‘default order indicator’ option for generating XSD by Instant Generator - , ,
Supported char type for generating XSD with extends string
General Modeling
Fixed unable to apply change of stereotype Line color
Fixed missing transitor popup in published outcome
Fixed instances loose the assigned slot values when copying instance specification along with its class definition
Supported showing business rules’ text in Select Model window (in addition to their names)
Reporting
Fixed a null pointer exception when publishing
Fixed supplier and client swapped for report composer template: Package.Dependency
Fixed a performance issue when opening pool specification
Fixed unable to connect data association and black box pool with anchor
Project Referencing
Fixed project references are lost when the user saves a project that was open in read-only mode
Interoperability
Fixed exporting XML missing stereotypes’ formatting
Reporting
Fixed Word document exported from report composer failed to apply style defined in Word template if the style name contains space
Fixed project publisher outcome failed to show table border for HTML documentation content
Code Engineering
Fixed C++ round-trip code generation creates duplicated comment for constructor
Project Referencing
Fixed moving referenced class’es operation moves the operation in referenced project
Fixed stereotype and template parameter type for a mirror element lost after removing reference project
Requirements Modeling
Supported editing test plan steps in all editions
ElaborView
Fixed ElaborView Web cannot show image shape in Chrome
General Modeling
Fixed package names show repeatedly in diagram title bar when add a package to sub-diagram as master view
Fixed wrong options window path in tips
Fixed setting an inner sub-process to be instantiated by event caused the contained start event not selectable
Fixed labels of association ends move after switching nickname
Fixed failed to inline edit requirement attributes
Supported duplicating model element with its children (right click on an element and select Duplicate Recursively)
Added zoom buttons in Diagram Overview pane in SDE
Code Engineering
Fixed Java round-trip does not support Java 7 ARM
Database Modeling and Engineering
Fixed missing Go statement after Create View in DDL
Automatically set association end ordered when synchronize from class diagram to ERD if association’s ORM collection type is set to be List
Team Collaboration
Fixed unable to update project from server when enabled ‘Show View’
Requirements Capturing
Supported selecting encoding when importing text file into Textual Analysis
ElaborView
Fixed unable to get ElaborView submission caused by having invalid characters in project name
Fixed zoom function of ElaborView do not work properly if I open and close the documentation
