I’m trying to install Visual Paradigm 15.0 and after the install4j Wizzard is prepared, an error occurs:
java.lang.ClassCastException; com.install4j.runtime.beans.action.misc.LoadResponseFileAction cannot cst to com.install4j.api.screens.Screen
I’ve tried also to install the freeinstall but when i click to exe application noyhing launching.
thx
the log file is:
Exception:
java.lang.ClassCastException: com.install4j.runtime.beans.actions.misc.LoadResponseFileAction cannot be cast to com.install4j.api.screens.Screen
at com.install4j.runtime.installer.config.ScreenBeanConfig.setBean(ScreenBeanConfig.java:88)
at com.install4j.runtime.installer.config.AbstractBeanConfig.finishBatch(AbstractBeanConfig.java:58)
at com.install4j.runtime.installer.ContextImpl.registerScreens(ContextImpl.java:694)
at com.install4j.runtime.installer.controller.Controller.start(Controller.java:75)
at com.install4j.runtime.installer.Installer.runInProcess(Installer.java:58)
at com.install4j.runtime.installer.Installer.main(Installer.java:45)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:81)
at com.exe4j.runtime.WinLauncher.main(WinLauncher.java:94)
at com.install4j.runtime.launcher.WinLauncher.main(WinLauncher.java:25)
System properties:
sun.desktop=windows
awt.toolkit=sun.awt.windows.WToolkit
java.specification.version=9
file.encoding.pkg=sun.io
sun.cpu.isalist=amd64
sun.jnu.encoding=Cp1252
java.class.path=C:\Users\HP8470~1\AppData\Local\Temp\e4j315.tmp_dir1536577643\i4jruntime.jar;C:\Users\HP8470~1\AppData\Local\Temp\e4j315.tmp_dir1536577643\user.jar
sun.awt.enableExtraMouseButtons=true
java.vm.vendor=Oracle Corporation
sun.arch.data.model=64
install4j.exeDir=C:\Users\HP 8470P\Desktop
user.variant=
java.vendor.url=http://java.oracle.com/
install4j.systemLanguage=fr
user.timezone=Africa/Casablanca
os.name=Windows 7
java.vm.specification.version=9
user.country=FR
sun.boot.library.path=c:\users\hp8470~1\appdata\local\temp\e4j315.tmp_dir1536577643\jre\bin
sun.java.command=C:\Users\HP 8470P\Desktop\Visual_Paradigm_CE_15_1_20180807_Win64.exe
jdk.debug=release
sun.cpu.endian=little
user.home=C:\Users\HP 8470P
exe4j.unextractedPosition=81729131
user.language=fr
java.specification.vendor=Oracle Corporation
java.home=c:\users\hp8470~1\appdata\local\temp\e4j315.tmp_dir1536577643\jre
file.separator=
java.vm.compressedOopsMode=32-bit
line.separator=
java.specification.name=Java Platform API Specification
java.vm.specification.vendor=Oracle Corporation
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
exe4j.moduleName=C:\Users\HP 8470P\Desktop\Visual_Paradigm_CE_15_1_20180807_Win64.exe
exe4j.tempDir=C:\Users\HP8470~1\AppData\Local\Temp\e4j315.tmp_dir1536577643
user.script=
exe4j.consoleCodepage=cp0
sun.management.compiler=HotSpot 64-Bit Tiered Compilers
exe4j.isInstall4j=true
java.runtime.version=9.0.1+11
javax.xml.parsers.SAXParserFactory=com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl
user.name=HP 8470P
path.separator=;
os.version=6.1
java.runtime.name=Java™ SE Runtime Environment
sun.java2d.noddraw=true
file.encoding=Cp1252
java.vm.name=Java HotSpot™ 64-Bit Server VM
exe4j.semaphoreName=Local\c:_users_hp_8470p_desktop_visual_paradigm_ce_15_1_20180807_win64.exe
install4j.appDir=C:\Users\HP 8470P\AppData\Local\Temp
java.vendor.url.bug=http://bugreport.java.com/bugreport/
java.io.tmpdir=C:\Users\HP8470~1\AppData\Local\Temp
java.version=9.0.1
user.dir=C:\Users\HP8470~1\AppData\Local\Temp\e4j315.tmp_dir1536577643
os.arch=amd64
java.vm.specification.name=Java Virtual Machine Specification
java.awt.printerjob=sun.awt.windows.WPrinterJob
sun.os.patch.level=Service Pack 1
java.library.path=C:\Users\HP8470~1\AppData\Local\Temp\e4j315.tmp_dir1536577643\user;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files\IBM Informix Software Bundle\bin;C:\ProgramData\Oracle\Java\javapath;c:\Program Files (x86)\Intel\iCLS Client;c:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\Intel\Intel® Management Engine Components\DAL;C:\Program Files\Intel\Intel® Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel® Management Engine Components\IPT;C:\Program Files\IDM Computer Solutions\UltraEdit;C:\SeleniumGecko;C:\Program Files\nodejs;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit;C:\Program Files\Git\cmd;C:\Program Files\Java\jdk1.8.0_181\bin;H:\apache-maven-3.5.0\bin;C:\Users\HP 8470P\AppData\Roaming\npm;C:\Program Files\Microsoft VS Code\bin;c:\users\hp8470~1\appdata\local\temp\e4j315.tmp_dir1536577643\jre\bin
java.vm.info=mixed mode
java.vendor=Oracle Corporation
java.vm.version=9.0.1+11
sun.io.unicode.encoding=UnicodeLittle
java.class.version=53.0
exe4j.launchName=C:\Users\HP 8470P\Desktop\Visual_Paradigm_CE_15_1_20180807_Win64.exe
