VP-UML 10.0, BP-VA 10.0, Agilian 10.0, Teamwork Server 10.0
Build 20120702
Products
Visual Paradigm for UML 10.0
Business Process Visual ARCHITECT 10.0
Agilian 10.0
Fixes and Enhancements
General Modeling/Diagramming
Fixed unable to collapse class after showing attribute as association
Supported following master view’s formatting when visualizing element
Supported connecting activity and port with exception handler
Fixed parallel gateway become non parallel upon reopening project
Documentation Editor
Fixed unable to convert highlighted text to bullet point
Team Collaboration
Fixed a problem with merging branch
Fixed unable to commit project after upgrading to new version
Fixed ClearCase branch creation problem
Build 20120706
Products
Agilian 10.0
Fixed unable to find tagged value using the Find function, when it is floating number with “15e3” as value
Fixed mis-placed connectors in BPD when dragging shapes
Supported synchronizing flow of events to activity diagram using Open API
Reporting
Fixed gradient fills on Freehand shape does not show on PDF report
Team Collaboration
Fixed activation detached from recursive message after committing
Fixed a problem related to merging trunk to branch
Hibernate/ORM
Fixed fail to reverse Oracle DLL with "||"
Fixed a bug related to ORM generation after converting to version 10
Model Exchange/Interoperability
Supported exporting indices to Excel
Build 20120712
Products
Agilian 10.0
Fixed tagged values appear to be name of stereotype in property pane
Fixed non-desired layout for activity diagram synchronized from flow of events
Fixed model elements aren’t sorted by name in ascending order in Model Explorer
Fixed additional tagged values in stereotypes not applied to all model elements
Fixed unable to generate report from flow of events
Team Collaboration
Fixed unable to merge branch to trunk
Fixed incorrect latest server revision show in Commit window when using SVN
Hibernate/ORM
Fixed unable to reverse Postgre’s DDL with UTF-8 encoding
Fixed ORM User Type not generate proper fully qualify name
Build 20120715
Products
Agilian 10.0
Fixed duplicate connector choice for connecting SysML property with mouse gesture
Fixed slow when try to add file reference for file that is on network drive
Fixed fact type snapped by parent package
Fixed namespace compartment too close to name of block
Fixed incorrect diagram hierarchy produced by importing project
Fixed unable to create BMM business process, regulation, resources, offering from tree
Fixed BMM Asset failed to list Category in specification window
Fixed zoom in/out with keyboard on Mac doesn’t show the gray box that indicates zoom ratio
Fixed phase entered in relationship specification put far away from relationship
Supported scrolling diagram when trying to drop a dragging column to an entity out of the visible region of current screen
Supported “None” shape type style in report generation
Improved inline editing performance when model completion is on
Team Collaboration
Fixed bad activation width after committing
Reporting
Fixed incorrect image size for image in flow of events in exported report
Made the option “Always Show Indicators” for publisher independent from "Show Model Element Indicators"
Provided option to hide out the “link” in publisher
Hibernate/ORM
Supported reversing Hibernate mapping file via command line
Build 20120718
Products
Agilian 10.0
Fixed inline editing does not working IntelliJ integration
Fixed slow in requirement & actor grid
Fixed unable to add existing diagram to connector as sub-diagram
Fixed interaction use’s arguments lost when project was saved by previous version
Supported editing documentation template
Code Engineering
Fixed instant reverse Java classes may produce diagram rendering issue caused by exception defined
Team Collaboration
Fixed unable to merge branch to trunk when branch is in old version
Interoperability/Model Exchange
Fixed export XMI in miss out operation’s raised exceptions
Build 20120721
Products
Agilian 10.0
Fixed indicator icons show in exported image
Fixed cannot set diagram to sub-process when the type is embedded sub-process
Fixed unable to add class and operation to flow of events at the same time
Fixed missing tag when create composite stereotype with tag in referenced project
Fixed several issues when removing classifier from instance specification
Improved documentation font’s display font size
Supported showing revision number in diagram info shape with variable ${teamworkRevision}
Team Collaboration
Fixed delete a BPMN lane and commit does not resize pool
Fixed InvocationTargetException when committing project when teamwork files have same file name
Fixed Update window (show when updating from server) shows Commit content
Fixed wrong connector end position in ERD after committing
Code Engineering
Fixed instant reverse fail on Python
Reporting]
Fixed temp file left after generating PDF report
Fixed export and import report template with html+image does not work
Fixed import BPMN creates duplicated diagram
Fixed export and import BPMN duplicates tagged values
Hibernate/ORM
Fixed different precision in mapping for ORM Persistable and ORM User Type
Build 20120725
Products
Agilian 10.0
Fixed BPMN communication detached from conversation link when dragging its parent’s parent package
Fixed cropped caption after reopening project for shape showed as image
Made Find function consider currently selected project when working with referenced project
Team Collaboration
Fixed null pointer exception when committing (related to nickname)
Fixed reference project lost (related to teamwork)
Build 20120731
Products
Agilian 10.0
Fixed BPMN data object not allow to change type
Fixed unable to change message to associated with message flow
Fixed change type on duplicated model moves “changed” element’s position
Made attribute follow role name when create from role
Supported “Show View” for composite model elements (e.g. attribute)
Supported renaming attribute in Model Explorer
Supported changing the presentation of glossary text in shape body
Team Collaboration
Fixed bad sequence flow ID caption position after committing
Fixed bad fact type label position after committing, caused by nickname
Fixed failed to use command line to update teamwork project
Fixed null pointer exception when updating the project
Fixed commit after applying design pattern produced model-less elements
Fixed migration of Teamwork Server does not handle branch properly
Project Referencing/Refactoring
Fixed refactoring failed to handle transition properly
Made refactoring auto clear master view
Improved log message produced when refactoring
Disallowed creating lane in referenced pool
Simulacian/Animacian
Fixed attached intermediate event cannot be the start of the process in Animacian
Fixed error wrongly detected in Animacian path
Fixed Animacian path executed twice
Supported terminate event in Animacian
Fixed memory issue when export XML
Fixed diagrams not list in proper hierarchical order in imported project
Fixed redundant business rule keyword set produced by importing project
Fixed unable to open configure stereotype window after importing stereotypes
Reporting
Improved report preview panel to show progress information
Improved publisher performance
Enforced title follow to page break in report composer
Code Engineering
Fixed Java round-trip generate code to wrong plugin project
Build 20120735
Products
Agilian 10.0
Fixed set ‘Unspecified’ to message flow for message does not clear message shape attached to flow
Fixed wrongly accepted package as attribute type when supply package type during inline editing of attribute
Fixed missing preview for interaction use
Fixed missing color for imported Visio stencil
Fixed lifeline caption detached from lifeline shape when created from seq diagram lifeline
Fixed slow documentation editing
Fixed unable to create tagged values via property pane
Fixed adding stereotype to class does not reposition template parameter
Fixed freehand connector detached from freehand shape after reopen project
Made child specification window modal
Supported converting image shape to concrete element type (e.g. class) with image kept
Supported attaching ports to objects in composite structure diagram
Supported resizing image in flow of events editor
Supported setting interface’s presentation to make it show as interface ball
Team Collaboration
Fixed requirement ID increased by one after committing
Fixed unable to update Teamwork project via command line
Fixed unable to merge between trunk and branch
Fixed unable to migrate Teamwork Server version 4.2
Fixed fail to migrate project with non-English file name
Fixed stereotype tagged values broken after SVN commit
Fixed qualifier lost after committing project
Showed progress when migrating Teamwork Server
Fixed unexpected changes caused by importing non-modified XML file exported before
Fixed duplicate ID found when creating BPMN element after importing XML
Supported Importing XML with new ID assigned to imported elements
VP-UML 10.0 Build 20120804 ChangeLog
Products
Agilian 10.0
Fixed instance specification classifier selection become part of the instance specification name
Fixed application always starts in full screen in Mac
Fixed spell checking wrongly underline correct text
Fixed slow shape creation in Eclipse integration
Fixed cropped association when open another diagram during the editing
Fixed null pointer exception when assign domain to entity
Fixed nickname doesn’t work for fact type
Fixed unable to rename tagged value via its specification window
Fixed double click on tagged value popup specification window twice
Fixed unable to delete document template
Fixed redundant space between edge of state shape and its connector
Fixed several performance issues related to the attribute specification window
Fixed unable to connect BPMN tasks with sequence flow when tasks are inside BPGroup inside BPPool
Fixed undo delete grid rows changed the ordering of items when reopen project
Fixed unable to bring shape to front
Fixed several issues related to the editing of template parameter in specification window or through inline editing
Fixed SQL error when setup/create user in VP Server (for ElaborView)
Fixed unable to create folder in Logical View
Fixed unable to show tagged values in shape in diagram of referenced project
Changed show/hide resource icons’ hotkey to Ctrl-Alt-R
Disallowed creating multiple stereotypes in same name
Disallowed a deletion action in documentation edition which might potentially corrupt the documentation content
Reduced spaces between element link and text in flow of events in PDF report
Enhanced performance on Tablet
Supported sorting in transit window
Supported transiting to multiple model elements in glossary grid
Supported find project data in reference project for the Find function
Supported specifying <> class’s presentation as interface ball
Supported business key in JPA
Supported adding label to multiple glossary terms
Team Collaboration
Fixed connector caption moved after creating pool and commit
Fixed stereotype color not apply after commit
Fixed commit doesn’t preserve re-assignment of model element of detached shape
Fixed removing all reference project and commit failed to remove any referenced project
Fixed VP Server runs out of memory when being started as service
Fixed unable to open other revision via Teamwork Client window
Fixed bad preview in Commit window
Fixed delete link in communication diagram and commit does not remove messages attached with link
Fixed a layout issue in the Commit window
Supported sorting in Manage Project window of Teamwork Client
Fixed glossary not being imported from .vpp file
Fixed a null pointer exception when import XML
Project Reference
Fixed unable to copy template parameter documentation from the specification of referenced class
Fixed delete reference shape does not cause its specification window be closed
Fixed project reference indicator for connector sometimes lost when resize
Fixed association no longer connected to attribute after converting reference shapes to mirror
Refined checking of cyclic project reference
Disallowed user to create lane to referenced pool
Supported selecting reference project’s types when editing template parameter
Removed warning when trying to copy image from diagram of referenced project to current project
Data Moedling/Hibernate/ORM
Fixed Oracle scale for column not shown in generated outcome
Supported UUID for PostgreSQL
VP-UML 10.0 Build 20120812 ChangeLog
Products
Agilian 10.0
Fixed unable to add requirement from other project to use case
Fixed synchronize from sequence diagram to communication diagram failed to show return message
Fixed table in grid diagram’s documentation is generated in wrong width in report
Fixed resource centric icons cannot be shown completely when the shape is put near diagram border
Fixed undo and redo create lifeline moves caption to far away
Fixed unable to drag and drop component with port presented from Model Explorer to diagram
Fixed copy and paste shape ignores line breaks in shape
Fixed connector pin does not work
Fixed slow type select in attribute specification window
Fixed unable to paste image to diagram via Ctrl-V
Fixed undo and redo creating shapes in sequence diagram produce corrupted sequence diagram
Supported defining default font size for text in textual analysis
Team Collaboration
Fixed hang when merging
Fixed slow updating from server
Fixed Teamwork Client doesn’t list any project when server is down
Fixed project properties lost after commit
Fixed Commit preview shows detached shape
Removed “Permissions” in LDAP Setting
Added LDAP identity in teamwork user and user group
Supported auto refreshing users from LDAP server
Supported configuring multiple LDAP servers
Disallowed several illegal merge action between trunk, tag and branch
Changed “Preview” button to “Next” in conflict window
Project Reference
Fixed publish content cannot show referenced project documentation image
Fixed an error when switch reference project from Diagram Navigator
Fixed cancel adding reference project will loss local modification
Fixed autorecovery of project won’t resolve project dependency
Disallowed editing term mirrored from reference project
Data Modeling/Hibernate/ORM
Fixed an error when synchronize from class diagram to entity relationship diagram
Supported personal & production DB connection setting for all DB configurations
Build 20120831
Products
Agilian 10.0
Fixed unable to show return type field in operation specification window
Fixed font size in glossary label not follow to grid setting
Fixed incorrect row height when fitting rows in grid diagram
Fixed opening panes are not memorized in NetBeans
Fixed ‘Select in Tree’ selected wrong element in Model Explorer
Fixed clicking OK in transit window erases all transit relationships
Removed the auto-expand and containment behavior
Supported opening project with specifiy model element selected through the use of command 'openlink ${link}'
Supported creating sub-diagram for class opearation
Activity Diagram
Fixed mis-placed connectors and shapes’ captions after undo creating shapes with branch resources
Fixed mis-placed connectors after undo resizing partition
Fixed create action in swimlane cell cause another cell lost, when fit shape size is on
Fixed action appear in both swimlane and partition in Model Explorer
Fixed unable to create shape in inner swimlane through the use of resource-centric interface
Fixed reorder swimlane partition makes partition order wrong after committing
Fixed connector slightly detached from action when resizing swimlane
Fixed incorrect horizontal partition bound after committing
Fixed creating vertical partition expands existing horizontal partition
Fixed wrong z-order of contained shapes after undo redo delete partitions
Fixed operand lost after committing (with content pasted from another diagram)
Fixed unable to move activation with self-message from 1 lifeline to another
Fixed empty swimlane left behind when deleting all partitions
Fixed swapped partitions after pasting swimlane
Improved the way objectNode is moved when partition is being resized
Sequence Diagram
Fixed a problem related to deleting lost message in sequence diagram
Fixed duplicate lifeline produces wrong sequence number
Fixed inner combined fragment moved after committing
Fixed activation lost after committing project when the activation was moved from another lifeline
Fixed sweeper actions affected unrelated messages in sequence diagram
Fixed broken sequence diagram when create found message inside interaction use
Team Collaboration
Fixed dangling anchor connector produced when a client delete sequence message and another client create note
Fixed PostMania not support reference project
Fixed unable to render UI diagram shape in command line or PostMania
Fixed PostMania does not work well on IE 7
Fixed commit after set stereotype to class cause connector be inserted into stereotyped class
Improved the way conflicts are listed in conflicts window
Project Reference
Fixed unable to re-use glossary label from referenced project
Fixed duplicate model element from reference project for modification also modifies the source element
Fixed mis-placed text cursor when pressing Enter in front of a list item in documentation editor
Fixed cut list item in documentation editor doesn’t give correct item number to the remaining, subsequent item
Code Engineering
Fixed Python generator does not generate comment as docstring
Fixed generated Python code failed to handle constructor
Fixed instant reverse Python missed out some of the attributes
Reporting
Fixed corrupted table in exported report due to the use of rowspan in
tag in HTML documentation
Fixed bad scale of diagram in exported report
Fixed generating wrong timestamp datatype for MSSQL
Interoperability
Fixed import and export XML cause Diagram Navigator dead
Fixed exported Excel does not contain project management properties for glossary terms
Support associating elements with fully qualified name in Excel import/export
Build 20120920
Products
Agilian 10.0
Fixed class isn’t listed when selecting class for object node, if the class’s parent is not a class/root
Fixed strange manual ordering in modeling explorer
Fixed zoom in requirement diagram does not update the bound of wrapped text in requirements’ body
Fixed missing popup menu when right click on activation in sequence diagram transited from another diagram
Fixed a memory issue that happened when right clicking on shape in Visual Studio integration
Fixed delete lifeline may not properly move the activations attaching to other affected lifelines
Fixed documentation pane is editable for referenced shape
Fixed unable to drag part from model explorer into component shape
Fixed a number of issues related to undo/redo in sequence diagram
Fixed requirement created when diagram is zoomed
Fixed undo deleting interface ball class failed to restore its caption location
Supported setting master view
Updated Czech language file
Activity Diagram
Fixed resize region in state cause state in wrong size
Fixed undo when activity diagram zoomed damaged caption labels
Fixed activity region destroyed when dragging across partitions
Fixed a problem associated with else clause in conditional node caused by resizing node
Business Process Modeling
Fixed sweep BPD and scroll down by mouse wheel destroy diagram content
Fixed sweeper cause data object’s caption move away and produced disconnected connector
Fixed wrong z-order of containing shape when setting parent lane for a lane
Fixed unable to make part in composite class nameless
Fixed several issues associated with using magnet/sweeper in BPD
Fixed cut and paste of an BPMN element creates multiple copies
Supported line wrapping on BPMN datastore shape
Reporting
Fixed slow text box editing in report diagram
Fixed report diagram does not render events’ triggers and results
Supported exporting report diagram via command line
Interoperability
Fixed stereotype color missing in XML import/export
Improved Excel importing speed
Team Collaboration
Fixed VPServer service does not work for 64 bit installers
Fixed project showing multiple times in PostMania
Fixed size of interaction operand not retain after committing
Fixed sorting in Diagram Navigator is not committed to server
Supported committing code synchronizing paths setting to server
Build 20121003
Products
Agilian 10.0
Fixed bad shapes’ position for imported Rose shape after save and reopen project
Fixed a tiny horizontal line is rendered when creating Product via resource
Fixed incorrect highlighting for glossary term due to the existence of non-English characters
Fixed message not attach to concurrent after dragging from lifeline
Fixed wrong ordering of tagged value after undo removal
Fixed StackOverFlow when cancel after overloading operation
Fixed duplicate model element recursively produce bad z-order of shape
Fixed redundant gate created in frame in sequence diagram
Fixed duplicate multiple members become duplicate parent
Improved speed of rendering matrix
Prompted user when starting the tool if user home is not writable
Prompted user when saving project if user had removed project reference during session
Supported displaying use case extends condition in diagram
Reporting
Fixed bad layout of matrix in report (exported from report composer)
Fixed wrong paper size for report exported from report composer
Fixed image step over page footer separator in report exported from report composer
Improved speed of PDF report generation
Fixed collapsed table in report exported from report composer
Improved spacing between elements in report composer (both preview and output)
Team Collaboration
Fixed sub-process shape put behind group after committing project, if the sub-process was created by splitting flow
Fixed several teamwork operations that cause temp files left behind
Fixed nothing to commit when modified shape caption size
Supported real deletion of Teamwork project file
Activity Diagram
Fixed resize conditional node does not update the position of clause text (if any)
Fixed exception threw when removing activity parameter from parameter set
Fixed label for activity parameter node trimmed
Fixed bad condition node region clauses bound after sweeping content
Hibernate/ORM/Database Engineering
Fixed missing timestamp type for SQL Server
