VP-UML 10.1, BP-VA 10.1, Agilian 10.1, Teamwork Server 10.1
Build 20130124
Products
Visual Paradigm for UML 10.1
Business Process Visual ARCHITECT 10.1
Agilian 10.1
Fixes and Enhancements
General Modeling/Diagramming
Fixed exception throw when there is a nameless connector node in Diagram Navigator
Fixed incorrect prompt for reference project when opening project under Visual Studio integration
Fixed incorrect prompt for reference project when commit under Eclipse integration
Build 20130125
Products
Agilian 10.1
Fixed transition lost after committing project (case specific)
Build 20130127
Products
Agilian 10.1
Fixed unable to list project after removing user group in Teamwork Server
Fixed unable to open diagram after update to 10.1 (user project specific)
Build 20130201
Products
Agilian 10.1
General Issues
Fixed refactoring wrongly included a diagram outside the scope
Fixed unable to cut and paste shape to new project
Fixed changing the name of template parameter causing attribute lost template info
Fixed undo pasting view may wrongly delete another view in addition to the current view
Fixed paste text into documentation without format incorrect removed a space character
Fixed exception throw when open a choreography task that was duplicate from reference project
Fixed bad rendering of cell in decision table after undo-ing the creation of condition row
Fixed diagram image shape not show up after creating by Open API
Fixed unable to send project to ElaborView Server
Fixed unable to get past the “Resolve Project Reference” window in Eclipse integration
Fixed role caption position in transited diagram is different from source diagram
Fixed creating Block Definition Diagram (with content) as subdiagram as rectangle throws exception
Fixed unable to create BMM’s InfluenceOrganization
Supported setting the ordering of diagrams listed in Export Diagram window to follow the ordering of diagrams in Diagram Navigator
Supported listing operations in matrix diagram
Improved the support of nickname in flow of events editor
Removed the drop down menu for project selection in Select Diagram window that shows when adding diagram reference
Code Engineering
Fixed C# IG didn’t handle the direction of the parameter
Fixed uni-directional association in XSD reversed as bi-directional relationship
Team Collaboration
Fixed application may hang when switching project revision
Fixed unable to commit in version 10.1 project saved under version 9.0
Fixed incorrectly report nothing to commit in Eclipse integration
Kept opening the active discussion in PostMania panel after committing project
Supported specifying Perforce workspace
Supported showing license status in Teamwork Server administration page
Reordered some of the popup menu items in the Teamwork Client window
Data Modeling/Hibernate/ORM/DB Engineering
Fixed multiplicity 1 caused the generation of nullable FK if association is having navigable
Fixed Oracle timestamp with local timezone being reversed as timezone
Fixed drag-and-drop to creating attribute-and-column mapping does not handle multiple views
Fixed mirrored ORM class lost ORM Persistable stereotype after synchronzing from ERD to class diagram
Fixed quote of discriminator annotation lost
Report Generation
Fixed incorrect font size in generated Word report, related to HTML text
Fixed some shapes failed to show the highlight of terms in publisher outcome
Supported decision table in report generation
Supported decision table in report composer
Build 20130202
Products
Agilian 10.1
Team Collaboration
Fixed a project commit problem related to committing project saved from version 9.0
Build 20130203
Products
Agilian 10.1
Code Engineering
Fixed Java round-trip wrongly produced ORM Persistable classes
Team Collaboration
Fixed commit incorrectly discarded diagram comment
Build 20130205
Products
Agilian 10.1
Team Collaboration
Fixed a commit issue
Fixed a merge issue
Build 20130302
Products
Agilian 10.1
General Issues
Fixed an empty line is produced when pasting content into documentation editor using "past without format"
Fixed template parameter not correctly add to documentation
Fixed matrix failed to skip attributes out of selected scope
Fixed unable to launch VP-UML 10.1 with product selector
Fixed mispositioned underline in flow of events editor (underline for mis-spelled words)
Fixed an undo problem in activity diagram
Fixed VP Update Server fails to download update for Logizian (formerly BP-VA)
Fixed a resizing issue related to fragment in sequence diagram
Fixed broken reference when moving a class member that is referenced by others
Fixed unable to open use case specification after copy and paste to new project
Fixed unable to open choreography task specification if pools are created in conversation diagram
Fixed a project open issue in VS integration
Improved the speed of merging model elements
Supported converting extremely old project file into latest version
Supported keeping children shapes when changing parent container’s type
Supported opening diagram link in documentation with Ctrl-Click
Supported defining stereotypes for Association End in Profile diagram
Code Engineering
Fixed Java Round-Trip reversed transient class as ORM Persistable
Fixed reverse engineering of C++ does not respect comment formatting
Fixed Java Instant Generator missing generate annotation for parameter
Team Collaboration
Fixed a commit issue related to the use of reference project in VS integration
Fixed unable to mass update Teamwork projects due to old version project file
Fixed incorrectly re-generate view when model element is deleted in server copy and the view is deleted in local copy
Fixed an update issue when updating via Teamwork Client
Fixed a commit issue related to the use of Perforce
Fixed a project check out issue in VS integration
Fixed unable to commit project converted from old version
Fixed hang when merging project
Fixed wrongly showed “null” in PostMania’s URL after enabled it
Fixed diagram comment lost after commit project
Fixed Teamwork Client may hang when repeatedly open different revisions for same project
Fixed a commit error
Supported migrating repository from SVN server to VP Teamwork Server
Fixed a problem with @JoinColumn association on entity classes
Fixed ORM natural Id in JPA always immutable
Fixed reversing timestamp and version from database
Supported reversing <> from database
Supported reversing Oracle complex type to ERD
Supported using the default value of column when generating sample data in DDL generation
Report Generation/Project Publisher
Fixed report generation does not work with decision table
Fixed table of content in generated report failed to show matrix diagram
Fixed abnormal alignment of conditions row header in decision table in publisher outcome
Fixed duplicated entries in summary table in generated report and published project
Made diagram in Word report generation expanded to fit page width
Enhanced printing of use case details
Improved the appearance of Project Publisher window
Removed redundant space in matrix cells in generated Word report
Supported selecting comment as a property of diagram in report template
Supported RACI in report template of Logizian (formerly BP-VA)
Supported resizing panels in report template window
Interoperability
Fixed transition lost in exported XMI
Fixed state’s entry/doActivity/exit lost in exported XMI
Fixed Activity’s body is imported as Constraint when import XMI
Mac Supports
Fixed product icon not displayed in tasklist (cmd-tab) or dock on Mac OS caused by a special application option
Removed redundant space in the application screen in Mac OS
Build 20130303
Products
Agilian 10.1
General Issues
Fixed unable to open a project created in version 10.0 (project specific)
Build 20130403
Products
Agilian 10.1
General Issues
Fixed unable to export diagrams when running with non-English language
Fixed conversation’s communication shape moved automatically
Fixed color of stereotype not applied to instance specification when assigning stereotype via specification window
Fixed the ‘Show Stereotype’ option has no effect on shapes after reopening project
Fixed unable to change diagram type in the New Diagram window
Fixed operand not correctly resized
Fixed documentation editor may fail to show the documentation of selected element
Fixed unable to wrap a shape label in case of a hyperlink
Fixed auto layout produce redundant white space in diagram
Fixed create choreography task with generic resource cause it auto complete inline editing
Fixed deleting communication diagram makes source sequence diagram lost its messages
Fixed wrapping class members cause code details disappear
Fixed choreography sub-process missing its child-relationships after exporting and importing
Fixed reference attribute lost when duplicate class
Fixed pool position changed when attempting to show lane in it
Fixed exception throws when assigning stereotype to viewless model element
Enhanced magnet behavior in sequence diagram
Avoided treating project modified when switching between diagram editors
Avoided copying cryptic characters into documentation editor that may lead to potential failure in report generation
Faster model element merging
Better support of merging decision table
Added popup menu for SysML Block for adding operation
Added connection rule for association from SysML block to actor
Code Engineering
Fixed an XSD generation problem with enumeration element documentation
Fixed an issue related to reverse engineering from JDK 1.7 source code
Fixed an issue related to the use of fully qualified in generated code
Team Collaboration
Fixed an InvocationTargetException during commit
Fixed application may hang when opening a project in old revision
Fixed IDE integration failed to load teamwork server login information after restarting
Fixed unable to close application due to the opened PostMania side panel
Fixed switch project doesn’t check for external changes made on Teamwork File
Fixed wrong project revision after committing project
Fixed nothing to commit when merge even Teamwork File is changed
Fixed unable to delete project on Teamwork Server
Supported detecting out of space in server and show better warning for it
Showed warning when try to install 32 Bit VP Server on 64 Bit OS
Fixed a DDL generation issue
Fixed synchronize between class and ERD may cause entity relationship disappear when working with multi-diagrams
Fixed a null pointer exception when generating ORM code
Fixed corrupted matrix diagram shows in report composer editor
Fixed tagged value listed twice in publisher outcome
Fixed publisher failed to process HTML tag in documentation if it is defined as glossary
Ignored Comment.comments and Reference.references in report template
Improved icon alignment in matrix in generated Word report
Diagram Navigator/Model Explorer/Class Repository
Fixed unable to delete decision table via Diagram Navigator
Fixed Diagram Navigator not showing a node of recovered shape resulted by importing project
Supported opening decision table by double clicking on decision table node in Model Explorer
Supported locking diagram when locking its parent model
Refactoring/Reference Project
Fixed sub-diagram not show under model element after refactor to ref project
Fixed several project refactoring issues
Fixed Show View doesn’t work well with referenced project
Supported showing port for components from reference project
Build 20130501
Products
Agilian 10.1
General Issues
Fixed exception throws when assigning stereotype to model elements that has no view
Fixed an issue related to importing EA file
Fixed referenced attribute lost when duplicate class
Fixed several element linkage issues for elements produced by transiting a diagram
Fixed import Excel doesn’t update attribute type according to Excel change
Fixed the rotation of text box is not available for undoing
Fixed removing attribute from class takes long time
Fixed found message ball covered by operand caption
Fixed irrelevant changes reported in Visual Diff
Fixed an issue related to auto resizing components
Supported merging decision tables
Suggest changing event type when attempting to connect a conversation with an BPMN event with link
Disallowed converting relationship to mirror when a container is being mirrored
Restricted the width of popup for operation selection in sequence diagram
Code Engineering
Fixed duplicated tagged values after running Instant Reverse
Fixed C++ code generation not generating initial value for enumeration class
Fixed C++ round trip forward generation improperly sets default argument values in operation implementations
Fixed round-trip engineering failed to reverse C++ enumeration
Team Collaboration
Fixed Collapse All button doesn’t work well in the Commit/Update window
Fixed an issue related to the rendering of images in PostMania
Fixed exception throws when merging
Fixed attribute name restore to default when being moved in nickname mode with project committed
Fixed Hibernate setLockMode() on criteria and query not work
Fixed exception throws when redo creating entity relationship
Fixed part of the documentation is missing for popup tooltip in project publisher outcome
Fixed the column width of grid in report doesn’t follow the width ratio in project
Fixed ‘Page Count’ variable not working in report composer
Fixed PDF report missing links for referenced glossary terms
Fixed label in grid step onto the next column in generated PDF report
Build 20130601
Products
Agilian 10.1
General Issues
Fixed sequence messages not put inside combined fragment after being pasted in a new sequence diagram
Fixed SVG image not resize when using as stereotype icon
Fixed bad rendering of text in diagram info shape when zooming diagram
Fixed unable to delete text with selection from right to left in cell in documentation pane
Fixed copy and paste association to new diagram does not cause its tagged value to show up after paste
Fixed an application UI rendering problem caused by documentation pane
Fixed wrong sort result for date columns in grid
Fixed exported Animacian failed to paint in some browsers
Fixed created BPMN shapes not follow default color setting
Fixed undo and redo resizing component produce misplaced port
Fixed bad rendering of attribute multiplicity
Fixed a bug related to documentation editing
Fixed Find & Replace wrongly apply formatting to text
Fixed Call Activity failed to render called element’s nickname
Fixed documentation indicator sometimes not working when in nickname mode
Skipped redundant space produced by hidden shapes when exporting image
Updated French translation file
Updated the coloring of control text in flow of events, making it more readable
Supported undo for creating model elements in Model Explorer
Improved the memory usage in exporting image
Supported updating attribute type mapping when performing ‘duplicate recursively’
Code Engineering
Fixed wrong typedef is generated by C++ instant generator
Fixed Quotes for JPA Entities not working
Fixed a problem about generating xmlns:null in XSD generation
Fixed an error in reverse engineering PHP
Supported typedef in C++ round-trip
Team Collaboration
Fixed nickname of annotation not committed
Fixed corrupted BPD after conflict resolution
Fixed reverse DDL missing relationships
Fixed documentation not being applied to column when applying a column domain
Supported UserType mapping in ORM Component
Supported qualified data types for reversing Postgres DDL
Supported the use of reserved words in table name if qualified, for reversing Postgres DDL
Supported the following create syntax when reversing Postgres DDL: [ ASC | DESC ] [ NULLS { FIRST | LAST } ]
Fixed different font family for matrix row text in generated HTML report
Fixed wrong direction of stroke for referenced URL presented in generated HTML report
Fixed unnecessary space in documentation in generated report
Limited the size of images in generated PDF report to not bigger than the table cell where the image is stored
Handled superscripts in generated Word report
Supported colored flow of events in generated HTML report
Supported publishing comment for entity column by project publisher
