VP-UML 11.0, Logizian 11.0, Agilian 11.0, Teamwork Server 11.0
Build 20140101
Products
Visual Paradigm for UML 11.0
Logizian 11.0
Agilian 11.0
Fixes and Enhancements
General Issues
Fixed documentation pane’s search function not working in Viewer Edition
Fixed Use Case Detail’s title not refresh upon the renaming of use case
Fixed multiple undo is required to remove a created BPMN lane
Fixed an IJ start-up issue wit IJ 13
Fixed a sequence message numbering issue
Fixed duration constraint caption disappear after undo deletion of shapes in sequence diagram
Fixed Sub-process diagram de-associated after importing BPMN
Fixed sweeper moves shapes to far away
Fixed diagram selection dialog box failed to show documentation in nickname
Fixed Use Case Note List’s focus consumed by note configuration pane
Fixed the New Diagram window in eclipse shows out of screen
Not to re-use project author from opened project
Improved captions in grid
Improved the sizing of headers in matrix/chart
Supported IPolygon.setPoints(Point[]) in OpenAPI
Updated Help Contents
Wireframe
Fixed resizing Alert View in wireframe may cause containing label shows out of shape
Fixed zooming in wireframe may may part of a label hidden
Fixed a menu containment issue in wireframe
Fixed several undo/redo issues in wireframe
Fixed Action Sheet point shows in bad location when creating Action Sheet from diagram toolbar
Fixed non-resizable wireframe elements being resized when being selected and resized with other shapes
Fixed Ctrl-A failed to work in wireframe when the wireframe is opened from Flow of Events
Fixed wireframe panel’s handler doesn’t follow mouse movement
Fixed handlers do not follow line or polygon when being moved by keyboard
Supported double clicking inside a wireframe table to create label
Supported creating new wireframe element by dragging a wireframe element with Alt key pressed
Supported Chinese content in wireframe
Supported deleting wireframe element via Edit menu
Updated the ordering of wireframe diagrams in menu
Avoided creating label that exceed cell range, in wireframe
Tasifier
Fixed Tasifier shows inbox message in wrong order
Fixed unable to use Tasifier after switching from trunk to branch
Fixed Tasifier window no longer in max state after committing
Fixed failed to show complete date picker if browser isn’t big enough
Supported showing selected task’s subject in page title of Tasifier
Supported deleting attachment in Tasifier
Supported showing member’s name on tooltip in Tasifier
Supported submitting a comment by pressing Enter in Tasifier
Added tooltip for an Edit button in Tasifier
Increased due date field’s width to make it visible on Mac (Tasifier)
Collaborative Modeling
Fixed a ClearCase login issue
Fixed unable to show user image in PostMania
Fixed an error that occurred when deleting project in server
Fixed empty Model Explorer when open an old revision in IJ integration
Reporting
Fixed non-working Project Publisher’s sort option - 'follow tree’
Fixed missing templates for DataStores shape in Report Composer
Fixed a Word report generation issue (project specific)
Code Engineering/ORM
Fixed broken link for SQLite .NET driver file
Fixed stop list in full text index not being reversed
Fixed search property list not being reversed in SQL Server 2012
Fixed round-trip failed to reverse C++ source due to attribute’s initial value
Build 20140203
Products
Logizian 11.0
Agilian 11.0
General Issues
Fixed undo creating return message cause part of the sequence message not rendered
Fixed several issues related to BPMN importing
Fixed no effect when clicking on Keep Change/Revert in Use Case Note List
Fixed bad resize behavior for free-hand shape
Fixed bad resize handlers’ positions of callout shape, when multi-selection
Fixed a project refactoring issue
Fixed unable to create use case from term in glossary grid
Fixed unable to add reference to documentation pane
Fixed incorrect font size for Flow of Events editor’s default font
Fixed incorrect synchronize result from class to ERD
Fixed floating resize handlers after visualizing use case created from glossary term
Fixed return type documentation lost when switch from HTML to Plain Text mode
Fixed floating connector end after removing column in entity and synchronizing to class diagram
Fixed relationship between sub-process and diagram lost after import of BPMN XML
Fixed wrong shape background color when create shape via resource centric interface
Fixed unable to save the change of color in matrix (diagram)
Fixed bad shape caption position when create shape at 140% zoom ratio
Fixed damaged ERD due to hidden columns in entity
Fixed state caption not auto wrap to multi-line after inline edit
Fixed inline editing of attribute type makes it wrongly associated to another class
Fixed unable to move the ‘diamond side’ of an aggregation (association)
Fixed Logical view folder being duplicated
Fixed the diagram link become plain text when copying from Flow of Events to documentation
Fixed unable to change font color for text in annotation
Fixed a connector problem when zoomed in BPD
Fixed a diagram rendering issue caused by the editing of free-hand shape
Supported opening use case details by pressing Enter
Removed caption placement options for free-hand shape
Wireframe
Fixed resize action sheet in wireframe doesn’t update the position of pointer accordingly
Fixed wrong row is removed in wireframe list view
Fixed popup menu in wireframe “dropped” to bottom after committing and updating
Fixed a performance issue related to wireframe
Fixed Ctrl-A not working in wireframe when the wireframe is opened in use case details
Fixed unable to play wireframe in IntelliJ IDEA (IDE integration)
Fixed bad resize behavior for Android seek bar
Fixed inconsistent wireframe preview size
Fixed redundant undo actions produced when using sweeper above frame in wireframe
Avoided wireframe annotation moved into browser by sweeper/magnet
Changed to use native file chooser for selecting image in wireframe image place-holder, on Mac
Supported undo/redo in desktop wireframe’s tree
Improved wireframe menu to support header with long text
Tasifier
Fixed Tasifier window no longer in max state after switching from trunk to branch
Fixed unable to show the entire sub-task name in Tasifier
Fixed unable to open Task Pool by URL
Fixed newly created task pool failed to appear in project task list of another client
Fixed unable to open task in Tasifier when back from Alt-Tab
Fixed inactive members listed in Tasifier
Fixed some lines in task details failed to appear
Fixed tag name in task log failed to update following the renaming of tag
Fixed unable to open task if the member involved is newly set to inactive
Fixed URL not updated when open task from inbox of Tasifier
Fixed unable to apply the change of tag due to the Apply button is put off-screen
Fixed task details wrongly overwritten by another task
Avoided posting commenting twice in Tasifier
Disallowed empty subject in Tasifier
Supported confirming task name by pressing Enter
Supported direct task creation in Task Pool of Tasifier
Supported attaching multiple files in Tasifier
Supported moving a task to another Task Pool when the Task Pool is shown outside the viewing region
Supported clickable link in task details
Improved the copy and paste of text in task in Tasifier
Improved timezone checking of Tasifier
Made closed tasks not to appear when viewing overdue tasks
Made verifier not to receive inbox notification when someone has completed a task
Update browser title after changing task name
Fixed action’s multiline caption cannot be shown in PostMania
Fixed ‘Find’ doesn’t include the comment of diagrams in search scope
Fixed wireframe label lost in child state after committing
Fixed deleted Teamwork Files still appear in PostMania
Fixed caption moved after committing project to server
Fixed unable to resolve a consecutive conflicts during commit
Fixed unable to commit project when there exists a diagram with very long name
Reporting
Fixed nickname does not work in report
Fixed the setting of cover page in Report Composer doesn’t follow Default page setup’s setting
Fixed bad image when publish project with hidden layer, with Project Publisher
Fixed bad font in Report Composer, when near the end of page
Fixed incorrect sort order in Report Composer
Fixed stake overflow when adding template to report in Report Composer (case specific)
Fixed Report in Report Composer failed to show “2nd level style” of Flow of Events
Fixed shape caption moved after switching nickname and refreshing report in Report Composer
Supported Use Case Note in Report Composer
Removed the “Save” button from Report Composer’s Editor Template window
Fixed problem in C# Hibernate code generation regarding association classes
Fixed missing generate annotation for referenced attribute form many to one
Fixed a SQL error when updating database
Build 20140301
Products
Logizian 11.0
Agilian 11.0
General Fixes/Enhancements
Fixed a stability issue caused by rotated text box
Fixed inaccurate connector end in process map diagram, caused by zooming
Fixed unable to edit the font size of text box
Fixed unable to play a wav file linked to documentation
Fixed potential application hang caused by auto save
Fixed undo and redo creating class causes association caption to disappear
Fixed a diagram rendering issue caused by business rule without a name
Fixed malfunctioning line jump
Fixed “Paint Connector Through Label” option not working properly
Fixed unable to control the sizing of Animation Panel
Automatically create associated actors when visualizing use case from Use Case List
Allowed deleting the root node of Zachman Framework via Model Explorer
Wireframe
Fixed inconsistent wireframe content in parent and child state
Fixed wireframe dialog failed to move properly following mouse pointer
Fixed wireframe change not preserved
Tasifier
Fixed task details in multi-line wrongly pasted as single-line
Fixed bad task name related to the use of Chinese character in task name
Refined the automatic scrolling behavior for comment pane in Tasifier
Refined the behavior of send and not to send inbox message, in Tasifier
Fixed unable to run Visual History (workspace specific)
Fixed wireframe changes made in branch not well merged to trunk
Fixed a stability issue related to wireframe and a teamwork operation
Fixed bad positioning of wireframe component after committing project
Fixed a project commit problem caused by the remapping of pool
Fixed logical view folder may be duplicated after committing project
Avoided project commit problem caused by long diagram name
Avoided potential problems caused by entering long topic name for PostMania
Avoided potential problems caused by importing project to server with very long project name
Reporting
Fixed drill down open reference wrongly generated file link
Updated Report Composer templates to remove the use of ReportOptionChecker
Improved the performance of Project Publisher when try to publish a logical view
Fixed an error related to ORM generation
Fixed an ORM code generation issue related to the use of ORM component class
Fixed a Hibernate inheritance mapping error in ORM generated mapping
Fixed missing attributes in generated ORM mapping file
Fixed a bad toString() method in generated ORM code
Fixed operation not generated as abstract in code generated through Instant Generator
Fixed a wrongly generated class name in build XML, from generated ORM code
Fixed a ORM Component attributes/fields names problem
Fixed a problem related to importing PHP code
Improved the handling of @Temporal for generated ORM code
Build 20140401
Products
Logizian 11.0
Agilian 11.0
Fixed removing assigned stereotype doesn’t revert color back to default
Fixed bad class shape size after showing attribute as association end
Fixed shape caption disappear after updating stereotype assignment
Fixed “Same Width” failed to update a shape within a selection
Fixed broken model when duplicate recursively
Fixed “Print Active Diagram” may not work when the active diagram is extremely large
Fixed a shape deletion problem
Fixed incorrect caption position when drag & drop shape from tree
Fixed “Restore to Default” restored wrong value to Project Options
Disallowed adding use case details to Logical View
Not to list model element in Viewless Model Elements window if the model element contains subdiagram
Code Engineering
Fixed unable to open Instant Generator window when there is no referenced project
Fixed a C++ code generation (Instant Generator) error
Fixed C++ code generation wrongly generate public class on template (Instant Generator)
Fixed a parse error when reversing C++ files
Fixed Java round-trip fail to reverse "try with resources"
Fixed unable to reverse C++ TypeDef
Supported friend operation in C++ code generation (Instant Generator)
ORM/Database Engineering
Fixed Oracle DDL wrongly generated when default value is space
Fixed default value not quoted in generated SQL
Fixed DDL file with inconsistent line ending
Fixed error creating sequence in generate database from ERD
Removed deprecated code for ORM code generation
Wireframe
Fixed unable to undo adjusting checkbox spacing in wireframe
Fixed unable to undo setting Android wireframe picker’s label
Fixed duplicating model that contains wireframe may cause commit project failed to work afterwards
Fixed part of the multi-line connector caption failed to appear in image in PostMania
Fixed unable to create task in Tasifier, when in I.E.
Fixed re-checkout project cannot be committed in IDE integration
Disallowed adding PostMania viewer as project member when importing project to server
Reporting
Fixed Report Composer template language failed to retrieve referenced element from referenced project
Fixed incorrect page number in report when exporting document with Word template
[reserved]
Build 20140906
Products
Logizian 11.0
Agilian 11.0
Fixed missing space between model element and text in report
Fixed importing Excel produce bad model
Build 20141001
Fixed several issues related to sequence diagram editor
Fixed a LDAP authentication issue
Fixed wireframe element moved after undo deletion and committing
Fixed a performance issue related to XML importing
Build 20141101
Fixed a performance issue related to copying shapes in wireframe
Avoided invalid characters in filename when saving
Disallowed adding referenced projects’ elements into Chart
Build 20141201
Fixed an issue that may cause Teamwork File be deleted after committing project
Avoided multiple ID fields in requirement
