Dear sir,
Here is an example which you can see in the attced files,In china i can’t find any books teach BPVA,I don’t know the details in setting the properties.though you have given me an sample at http://oldresources.visual-paradigm.com/vpsuite2.3sp2/generate_bpel_for_jboss.html
would you help me set the properties of the example,in order to make the the BPD transformed to BPEL? Thank you very much!
example.rar
Hi Happymixia,
Thanks for your post. I’ve forwarded the issue to our engineers to follow-up, and I’ll keep you informed for any news of this issue.
By the meantime, if you have any inquiries, please do not hesitate to contact me.
Dear sir,
Thank you for your help.
I look forward to hearing from you.
lixia
Hi Happymixia,
You are welcome. I’ll let you know if I get any news of this issue.
Hi Happymixia,
I would like to notify you that our engineers have prepare a sample for the setting properties issues, please download the sample from the following link.
http://files3.visual-paradigm.com/200805/Lilian/BPDTransformBPEL.zip
*Please be reminded that we just make the process seems to validate for JBoss jBPM, but indeed it doesn’t. Since it requires real property values/web service for executing BPEL, all the values in the sample are only temporary, hard code and may cause logical problem.
Since there are fixes in our application regarding to generating BPEL, please also download the build at the link below in order to get the same result as our engineers’.
http://files3.visual-paradigm.com/200805/Patch/sp1_20080513s/Business_Process_Visual_ARCHITECT_Windows_2_2_sp1_20080513s.exe
To use the patch:
- Exit any running instance of VP product
- Install by overwriting the current installation
- Restart the product
Note: This patch is made for BP-VA 2.2 SP1. Please make sure you have a valid product license. Otherwise you won’t be able to start up the product after the installation.
I hope it helps. If there are any further inquiries, please do not hesitate to contact me.
Dear sir,
Thank you for your reply, I eager to download the sample, I have tried many times,but I can't open the two pages you gived me.So I trouble you again,would you send it to my mailbox(happymixia@163.com)
or attach it in reply.
I’m very grateful for your help.
Best regards.
Lixia
Hi Happymixia,
Would you mind trying the following links? Thanks!
http://files4.visual-paradigm.com/200805/Lilian/BPDTransformBPEL.zip
http://files4.visual-paradigm.com/200805/Patch/sp1_20080513s/Business_Process_Visual_ARCHITECT_Windows_2_2_sp1_20080513s.exe
