We have a very big BPMN Diagram with a lot of lanes and pools. We have had mor Task and all the other tasks are no more tied to the lines. We had to clik on a line to have it re-connect to its tasks. As we have a lot of Tasks and more lines, it will be difficult to do it for every line.
Is there a workaround to have a good display.
(if my memory was good on older version there was a refresh diagram command, but i cannot find in on Agilian 1.4).
Thanks for your post. When you right-click on the diagram, you can select Layout > Route Connectors in the popup menu for connector layout. Is this what you are looking for?
Thanks for sending me the image. First of all, I would like to clarify that “Layout > Route Connectors” on connector’s popup menu will only affect connectors and models will not be influenced. You can have a try first and see if your connectors will be routed to attach the models again (if not what you want, simply Undo it will be fine).
If the connector layout does not work, could you please try Help > Maintenance > Repair Project and see if this helps?
*Please backup your project file first.
If these 2 ways cannot resolve your problem, would you mind sending your project file to lilian@visual-paradigm.com for investigation? Thanks in advance!
