Can I add Control Flow to the double-click popup in Visual Paradigm Community Edition?
When I double-click an empty area of an activity diagram, a popup appears with shapes to choose from. Is there a way to customize this popup and add Control Flow so I can select it directly there instead of using the left toolbar?
In our editor the connector cannot appear on its own without from/to element. Therefore clicking on the empty area of the diagram will not allow to create connectors from Resource Catalog. If you wish to create connector link to a new element then please click on any element on your diagram then drag out the Resource Catalog icon from its top-right, and drop to blank of the diagram to select target element plus connector to create. Or you can drop it over existing element to just create relationship between elements.
