I want to use the current VP with eclipse 5.1. Now here is the problem: after I start VP, the Program gets the licence key and I am asked to give a SDE SE-EC project path. No matter whether I choose “Create in default path” or something else, after I click “ok”, nothing happens. Eclipse simply tries to open my project in the repositoty (Openin project…and scrollbar moving from left to right and back all the time). I can’t do anything except to kill the eclipse process. What’s the Problem?
Thanks.
Hi user,
Thank you for your message and we are sorry for the problem. Would you mind to attach the followings so we can have a check? Thanks in advance!
- vp.log file in working directory of Eclipse
- Eclipse configuration details (can be found in About dialog), please save it in .txt file to attach it in your reply
- .log file in ${workspace}.metadata folder
thank you for your support. Here are the requested files.
Regards.
vp.log
no_name.log
configuration.txt
Hi user,
Thanks for replying with the files. From the configuration.txt you are using OpenJDK. Could you please change to standard Sun JDK and see if the problem persists?
I look forward to hearing your response.
