Mostly loving Visual Paradigm for UML, but got a very annoying problem that has happened a couple of times now…
Somehow, the project gets into a state where an item cannot be deleted - no matter what I do. Both times, the item has been an interface. It might be only interface items that do this - not sure.
…anwyay, I can’t delete the interface itself. I can’t delete any parent items (Port, class / part / object / whatever). I can’t delete the diagram it’s on! I can’t find any way to get rid of the particular item…
…except to scrap the project and start again!
…has anybody else had this? Is there a workaround?
Symptoms: Component diagram. After adding some connectors i cannot delete elements that connected to these connectors. I also cannot change or move connectors. Connectors not shown in the Tree. All is very slow.
Idea: You have a problem with your connectors. If i draw a connector, sometimes the aligment guide gets focus and connector is lost but added to the diagram.
Your hints could be very important. Let me ask more - Do you find this problem in Component Diagram? Are you able to reproduce it?
Also, if possible please send me your project to let our engineers help you fix it first. At the same time, we 'll try to produce and fix this problem.
Nevermind. Thank you for your attempt. I’ve captured a movie to show you how was I trying to repeat this problem but without success. Could you comment on my steps? I am afraid I have missed something important… Here is the movie: http://files3.visual-paradigm.com/200711/Jick/create-component.html
Thank you for your confirmation. By the way, one point I do aware in your project is that your Interface has a “GenericConnector” connected to the Component, but is invisible. I suspect that it is the generic connector that causes the problem. We will do some testing in this direction, too.
