I installed VP_Suite_Windows_NoInstall_5_0_20100901.zip on a Win xp Sp3 machine. When i run the VP Suite 5.0\bin\Visual Paradigm for UML 8.0.exe i get the following error message: “The JVM could not be started. The main method may have thrown an exception”
if the problem continues, make a change in the archive, open with notepad and modify “-Xms256m -Xmx1024m” to " -Xms256m -Xmx512m", the problem is because don’t have the ram to work with the configuration… i hope to work…
I used bat file, but it worked only with “-Xms256m -Xmx512m”. I get
“Cannot read Product and Edition
[Sat May 12 11:54:25 GMT+06:00 2012]:
Edition [VP-UML PE]: 8.0 (sp1_201010
Not running DB-VA or VP-UML using RV”
all the time.
With “-Xms256m -Xmx1024m” get error:
Error occurred during initialization of VM
Could not reserve enough space for object heap
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
