Test adapter connection failed!
v.yys: Connection timeout!
at v.bgz.i(:62)
at v.iteg.i(:126)
at v.hqd.F(:858)
at v.hqd.d(:32)
at v.shx.actionPerformed(:365)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$2.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at v.irqs.show(:427)
at v.iqok.y(:735)
at v.iqok.show(:745)
at v.icba.i(:54)
at v.icza.i(:97)
at v.erd.i(:61)
at v.ptt.b(:1656)
at v.ivej.i(:2897)
at v.ifhg.r(:154)
at v.uvj.actionPerformed(:63)
at javax.swing.AbstractButton.doClick(Unknown Source)
at com.jidesoft.plaf.vsnet.VsnetMenuItemUI.doClick(Unknown Source)
at com.jidesoft.plaf.vsnet.VsnetMenuItemUI$MouseInputHandler.mouseReleased(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
The problem may come from firewall, invalid port, accessing restriction and etc. Please use MySQL client to test the connection (PS. please test in the same machine as VPUML, and with the same user)
Jick[/quote]
Hi Jick, thanks…
Now is Ok, I connect with the hostname without port and the connect successful.
at v.bgz.i(:62)
at v.iteg.i(:126)
at v.hqd.F(:858)
at v.hqd.d(:32)
at v.iqok.y(:735)
at v.icba.i(:54)
at v.icza.i(:97)
at v.erd.i(:61)
at v.ptt.b(:1656)
at v.ivej.i(:2897)
at v.ifhg.r(:154)
