I would like to extract VPUML class diagrams from a bigger one and it doesn’t work under Linux (but it works under Wind32, I’ve tested it successfully).
In fact, when I open the new extracted VPUML project, the name of the class diagrams appear in VP Diagram Navigator without elements.
Nothing except the name appears also in Model Explorer and Class Repository.
Regards,
PS: When the diagram is exported, the current project is modified. Indeed, the package name is modified.
For instance I’ve exporter com.rsd.glass.igp.data, then it will be modified in com.rsd.glass.igp.data.data (this bug doesn’t appear under Win32).
Thanks for your post. Would you mind to attached your project file and tell me which diagram you exported, so we can have a check to the problems? Thanks in advance!
This issue is solved with the last patch: Build sp1_20090729e. I mean, it is possible now to see the exported class in the diagram navigator.
However, I can’t see any class in the class repository pane.
Thanks for replying and I’m glad that the patch helps. About the class models in Class Repository, I’ve forwarded the issue to our engineers to follow-up, and will come back to you once there is any feedback.
I would like to let you know that showing classes of linked project will be supported in next release (VP-UML 7.1), I’ll keep you informed for any news on this issue.
