Entity PK generated as number(19) by default. Can I change it’s length for the each PK-column?
Hi Eugeny,
I’ll check with our engineers and come back to you tomorrow.
Hi Eugeny,
You can simply change the length of PK column by inline editing of column (double-click the column can edit it). Also, you can export the entity relationship diagram (ERD) to Excel file, edit the length of PK columns and import the Excel back to the project - this is especially helpful for mass modification.
More details about edit and import Excel can be found from:
http://www.visual-paradigm.com/support/documents/vpumluserguide.jsp?pt=10&ch=3&sec=2
By the way, you can select the export style to facilitates modification on models - Diagram per Sheet, All In One Sheet and Model type per Sheet can be chosen when export Excel (you can refer to attached image)
Hope this helps. Please feel free to ask if there is any further question.
Thanks!
Hi Eugeny,
You are welcome.
