Hi, there,
I always get following exceptions when I run files generated for JPA by VP to create tables, this only happen in Many to many relationship with composited key. no link table.
java.lang.ArrayIndexOutOfBoundsException: 5
at org.hibernate.persister.entity.AbstractEntityPersister.initSubclassPropertyAliasesMap(AbstractEntityPersister.java:1618)
at org.hibernate.persister.entity.SingleTableEntityPersister.(SingleTableEntityPersister.java:429)
at org.hibernate.persister.PersisterFactory.createClassPersister(PersisterFactory.java:84)
at org.hibernate.impl.SessionFactoryImpl.(SessionFactoryImpl.java:267)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1341)
at org.hibernate.cfg.AnnotationConfiguration.buildSessionFactory(AnnotationConfiguration.java:867)
at org.orm.util.ORMSessionFactory.(ORMSessionFactory.java:17)
at org.orm.util.ThreadBaseSessionController.(ThreadBaseSessionController.java:26)
at org.orm.PersistentManager.(PersistentManager.java:90)
at com.dynadocs.vfs.SecureChannelPersistentManager.(SecureChannelPersistentManager.java:31)
at com.dynadocs.vfs.SecureChannelPersistentManager.instance(SecureChannelPersistentManager.java:70)
at ormsamples.CreateSecureChannelDatabaseSchema.main(CreateSecureChannelDatabaseSchema.java:11)
But the DDL script works fine. only I got those errors when I run code generated by VP.
Looking forward to your response .
thank you in advance.
Wen
