Hi everyone,
I found a strange issue while i was trying to associate some tables to a referenced project.
Here are some of the facts.
Erd1:
http://www.caspier.de/vp/erd1.jpg
As you can see there are two packages, the main package is the referenced project with one table, the businesspartner in this example.
With the extension-package i want to extend the businesspartner with new fields.
For comparing the issue i created the file-table, extended by a fileaddition-table in the same project.
Class1:
http://www.caspier.de/vp/class1.jpg
After synchronizing to the class diagram you can see, that there are no associations to the referenced project (main)
So I went forth boldly and draw them on my own, as you can see in Class2. I also changed the navigatable flag and set the persistable flag under specification association -> orm association detail to true.
Class2:
http://www.caspier.de/vp/class2.jpg
Synchronizing back to ERD i got the constellation in ERD2
Erd2:
http://www.caspier.de/vp/erd2.jpg
As you can see the file-tables are not influenced - everything is fine there. The referenced project table is now double associated…
Synchronizing back to class diagram, there seem to be no changes BUT within the associations the persistable flag is overwritten with false as you can see in Attrib1.
Attrib1:
http://www.caspier.de/vp/spezassociation.jpg
Synchronizing back one more time to ERD the picture is again the first one (ERD1).
So my main concern is the disappearance of the persistable flag of associations to referenced projects in the orm-class-model.
Within the same project there is no problem at all as you can see in the file-table above.
Any ideas on this problem?
Thanks in advance for your tips.
