Hi Jick,
Thank you for your response! For some reason, I cannot upload the log file because I am a ‘new user’? Anyway, here is the copy paste:
[2020/09/27 23:27:14] [message] [Sun Sep 27 23:27:14 CEST 2020]: Start Visual Paradigm [VP]: 16.2 (20200904)
[2020/09/27 23:27:14] [message] Operating system: Windows 10 10.0 running on amd64
[2020/09/27 23:27:14] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/09/27 23:27:14] [message] User: Robin, language: nl
[2020/09/27 23:27:14] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/09/27 23:27:14] [message] Memory: current=247M, max=989M
[2020/09/27 23:27:18] [message] start startup getLicenseKey on 27-Sep-2020
[2020/09/27 23:27:18] [message] getLicenseKey in local …
[2020/09/27 23:27:18] [message] getLicenseKey from server …
[2020/09/27 23:27:18] [message] finish startup getLicenseKey
[2020/09/27 23:27:18] [message] getVerifiedLicenseKey: null; state=Installed
[2020/09/27 23:30:19] [message] start startup getLicenseKey on 27-Sep-2020
[2020/09/27 23:30:19] [message] getLicenseKey in local …
[2020/09/27 23:30:19] [message] finish startup getLicenseKey
[2020/09/27 23:31:03] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/09/27 23:36:41] [message] Cannot write to folder: C:\Program Files\Visual Paradigm 16.2 (Access is denied)
[2020/09/27 23:42:29] [message] Exit Visual Paradigm
[2020/09/27 23:42:31] [message] Saved project “.systemproject” to “C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp”.
[2020/09/27 23:42:33] [message] System.exit: true
[2020/11/14 16:33:18] [message] [Sat Nov 14 16:33:17 CET 2020]: Start Visual Paradigm Standard [VP SE]: 16.2 (20201101)
[2020/11/14 16:33:18] [message] Operating system: Windows 10 10.0 running on amd64
[2020/11/14 16:33:18] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/11/14 16:33:18] [message] User: Robin, language: nl
[2020/11/14 16:33:18] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/11/14 16:33:18] [message] Memory: current=247M, max=989M
[2020/11/14 16:33:26] [message] start startup getLicenseKey on 14-Nov-2020
[2020/11/14 16:33:26] [message] getLicenseKey in local …
[2020/11/14 16:33:26] [message] finish startup getLicenseKey
[2020/11/14 16:33:45] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/11/14 16:34:02] [message] Opening Project: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp
[2020/11/14 16:39:59] [message] Cannot write to folder: C:\Program Files\Visual Paradigm 16.2 (Access is denied)
[2020/11/16 12:24:00] [message] [Mon Nov 16 12:24:00 CET 2020]: Start Visual Paradigm Standard [VP SE]: 16.2 (20201101)
[2020/11/16 12:24:00] [message] Operating system: Windows 10 10.0 running on amd64
[2020/11/16 12:24:00] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/11/16 12:24:00] [message] User: Robin, language: nl
[2020/11/16 12:24:00] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/11/16 12:24:00] [message] Memory: current=247M, max=989M
[2020/11/16 12:24:05] [message] start startup getLicenseKey on 16-Nov-2020
[2020/11/16 12:24:05] [message] getLicenseKey in local …
[2020/11/16 12:24:05] [message] finish startup getLicenseKey
[2020/11/16 12:24:19] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/11/16 12:24:32] [message] Opening Project: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp
[2020/11/16 12:30:20] [message] Cannot write to folder: C:\Program Files\Visual Paradigm 16.2 (Access is denied)
[2020/11/16 13:27:39] [message] [Mon Nov 16 13:27:39 CET 2020]: Start Visual Paradigm Standard [VP SE]: 16.2 (20201101)
[2020/11/16 13:27:39] [message] Operating system: Windows 10 10.0 running on amd64
[2020/11/16 13:27:39] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/11/16 13:27:39] [message] User: Robin, language: nl
[2020/11/16 13:27:39] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/11/16 13:27:39] [message] Memory: current=247M, max=989M
[2020/11/16 13:27:40] [message] start startup getLicenseKey on 16-Nov-2020
[2020/11/16 13:27:40] [message] getLicenseKey in local …
[2020/11/16 13:27:40] [message] finish startup getLicenseKey
[2020/11/16 13:28:10] [message] Exit Visual Paradigm
[2020/11/16 13:28:12] [message] Saved project “.systemproject” to “C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp”.
[2020/11/16 13:28:13] [message] System.exit: true
[2020/11/16 13:28:15] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/11/16 13:28:21] [message] Opening Project: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp
[2020/11/16 13:33:16] [message] Exit Visual Paradigm
[2020/11/16 13:33:17] [message] Saved project “.systemproject” to “C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp”.
[2020/11/16 13:33:18] [message] System.exit: true
[2020/11/29 18:20:52] [message] [Sun Nov 29 18:20:52 CET 2020]: Start Visual Paradigm Standard [VP SE]: 16.2 (20201101)
[2020/11/29 18:20:52] [message] Operating system: Windows 10 10.0 running on amd64
[2020/11/29 18:20:52] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/11/29 18:20:52] [message] User: Robin, language: nl
[2020/11/29 18:20:52] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/11/29 18:20:52] [message] Memory: current=247M, max=989M
[2020/11/29 18:20:56] [message] start startup getLicenseKey on 29-Nov-2020
[2020/11/29 18:20:56] [message] getLicenseKey in local …
[2020/11/29 18:20:56] [message] finish startup getLicenseKey
[2020/11/29 18:21:48] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/11/29 18:21:57] [message] Opening Project: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp
[2020/11/29 18:27:41] [message] Cannot write to folder: C:\Program Files\Visual Paradigm 16.2 (Access is denied)
[2020/11/29 18:31:12] [warning] Error in Attribute: -e-mail
[2020/11/29 23:07:30] [message] Exit Visual Paradigm
[2020/11/29 23:07:34] [message] Saved project “.systemproject” to “C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp”.
[2020/11/29 23:07:36] [message] System.exit: true
[2020/12/14 22:43:54] [message] [Mon Dec 14 22:43:54 CET 2020]: Start Visual Paradigm Standard [VP SE]: 16.2 (20201101)
[2020/12/14 22:43:54] [message] Operating system: Windows 10 10.0 running on amd64
[2020/12/14 22:43:54] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/12/14 22:43:54] [message] User: Robin, language: nl
[2020/12/14 22:43:54] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/12/14 22:43:54] [message] Memory: current=247M, max=989M
[2020/12/14 22:43:56] [message] start startup getLicenseKey on 14-Dec-2020
[2020/12/14 22:43:56] [message] getLicenseKey in local …
[2020/12/14 22:43:56] [message] finish startup getLicenseKey
[2020/12/14 22:48:50] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/12/14 22:48:59] [message] Opening Project: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp
[2020/12/14 22:54:32] [message] Cannot write to folder: C:\Program Files\Visual Paradigm 16.2 (Access is denied)
[2020/12/14 22:55:54] [message] Exit Visual Paradigm
[2020/12/14 22:55:56] [message] Saved project “.systemproject” to “C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp”.
[2020/12/14 22:55:58] [message] System.exit: true
[2020/12/15 21:33:21] [message] [Tue Dec 15 21:33:21 CET 2020]: Start Visual Paradigm Standard [VP SE]: 16.2 (20201101)
[2020/12/15 21:33:21] [message] Operating system: Windows 10 10.0 running on amd64
[2020/12/15 21:33:21] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/12/15 21:33:21] [message] User: Robin, language: nl
[2020/12/15 21:33:21] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/12/15 21:33:21] [message] Memory: current=247M, max=989M
[2020/12/15 21:33:27] [message] start startup getLicenseKey on 15-Dec-2020
[2020/12/15 21:33:27] [message] getLicenseKey in local …
[2020/12/15 21:33:27] [message] finish startup getLicenseKey
[2020/12/15 21:33:50] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/12/15 21:34:13] [message] Opening Project: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp
[2020/12/15 21:46:26] [message] Exit Visual Paradigm
[2020/12/15 21:46:28] [message] Saved project “.systemproject” to “C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp”.
[2020/12/15 21:46:31] [message] System.exit: true
[2020/12/15 21:46:54] [message] [Tue Dec 15 21:46:54 CET 2020]: Start Visual Paradigm Standard [VP SE]: 16.2 (20201101)
[2020/12/15 21:46:54] [message] Operating system: Windows 10 10.0 running on amd64
[2020/12/15 21:46:54] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/12/15 21:46:54] [message] User: Robin, language: nl
[2020/12/15 21:46:54] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/12/15 21:46:54] [message] Memory: current=247M, max=989M
[2020/12/15 21:46:55] [message] start startup getLicenseKey on 15-Dec-2020
[2020/12/15 21:46:55] [message] getLicenseKey in local …
[2020/12/15 21:46:55] [message] finish startup getLicenseKey
[2020/12/15 21:47:15] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/12/15 21:47:21] [message] Opening Project: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp
[2020/12/15 21:48:34] [message] Exit Visual Paradigm
[2020/12/15 21:48:36] [message] Saved project “.systemproject” to “C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp”.
[2020/12/15 21:48:38] [message] System.exit: true
[2020/12/15 22:19:39] [message] [Tue Dec 15 22:19:39 CET 2020]: Start Visual Paradigm Standard [VP SE]: 16.2 (20201203)
[2020/12/15 22:19:39] [message] Operating system: Windows 10 10.0 running on amd64
[2020/12/15 22:19:39] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/12/15 22:19:39] [message] User: Robin, language: nl
[2020/12/15 22:19:39] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/12/15 22:19:39] [message] Memory: current=247M, max=989M
[2020/12/15 22:19:41] [message] start startup getLicenseKey on 15-Dec-2020
[2020/12/15 22:19:41] [message] getLicenseKey in local …
[2020/12/15 22:19:41] [message] finish startup getLicenseKey
[2020/12/15 22:20:00] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/12/15 22:20:05] [message] Opening Project: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp
[2020/12/15 22:20:58] [message] Exit Visual Paradigm
[2020/12/15 22:21:00] [message] Saved project “.systemproject” to “C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp”.
[2020/12/15 22:21:02] [message] System.exit: true
[2020/12/15 22:21:25] [message] [Tue Dec 15 22:21:25 CET 2020]: Start Visual Paradigm Standard [VP SE]: 16.2 (20201203)
[2020/12/15 22:21:25] [message] Operating system: Windows 10 10.0 running on amd64
[2020/12/15 22:21:25] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/12/15 22:21:25] [message] User: Robin, language: nl
[2020/12/15 22:21:25] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/12/15 22:21:25] [message] Memory: current=247M, max=989M
[2020/12/15 22:21:26] [message] start startup getLicenseKey on 15-Dec-2020
[2020/12/15 22:21:26] [message] getLicenseKey in local …
[2020/12/15 22:21:26] [message] finish startup getLicenseKey
[2020/12/15 22:22:58] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/12/15 22:23:04] [message] Opening Project: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp
[2020/12/15 22:25:17] [message] Exit Visual Paradigm
[2020/12/15 22:25:18] [message] Saved project “.systemproject” to “C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp”.
[2020/12/15 22:25:19] [message] System.exit: true
[2020/12/16 09:09:19] [message] [Wed Dec 16 09:09:19 CET 2020]: Start Visual Paradigm Standard [VP SE]: 16.2 (20201203)
[2020/12/16 09:09:19] [message] Operating system: Windows 10 10.0 running on amd64
[2020/12/16 09:09:19] [message] Java VM: 11.0.7 OpenJDK 64-Bit Client VM, vendor 11.0.7+10 AdoptOpenJDK
[2020/12/16 09:09:19] [message] User: Robin, language: nl
[2020/12/16 09:09:19] [message] Installation ID: 5367b9b41373cd16cef7b9c331660ab0
[2020/12/16 09:09:19] [message] Memory: current=247M, max=989M
[2020/12/16 09:09:20] [message] start startup getLicenseKey on 16-Dec-2020
[2020/12/16 09:09:20] [message] getLicenseKey in local …
[2020/12/16 09:09:20] [message] finish startup getLicenseKey
[2020/12/16 09:09:34] [message] Workspace: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws
[2020/12/16 09:09:42] [message] Opening Project: C:\Users\Robin\AppData\Roaming\VisualParadigm\ws.vpprefdata.systemproject.vpp
Kind regards,
Robin
