Are you using our download function to download the JDBC driver? If so, please delete the $vp-suite-install-dir/ormlib/driver/postgresql.jar and download again. Please let me know if this helps. Thank you!
According to the log, it seems that you do not have permission to do the reverse. Can you confirm that your account has the permission to access the schema?
We tried to create a new user with minimum permission, then we get table name with columns. Once I grant select on tables, everything works fine.
GRANT SELECT ON TABLE “Frequence” TO user1;
GRANT SELECT ON TABLE “HistoriquePoint” TO user1;
GRANT SELECT ON TABLE “HistoriqueRoutine” TO user1;
GRANT SELECT ON TABLE “Point” TO user1;
GRANT SELECT ON TABLE “Routine” TO user1;
GRANT SELECT ON TABLE “TypePoint” TO user1;
Could you confirm if you have granted ‘select’ to the tables? It should work if you have done this.
