Hi, is there any way to change the default fonts used by SDE in SDE EE EC? The current font is serifed, is hard to read and takes up a lot of space.
thank you,
atle
thank you,
atle
Hi atle,
Thanks for your post. Could you please clarify which default fonts do you want to change, for the diagrams or the UI? Also, could you please provide me a screenshot of your current fonts? Thanks in advance!
As you can see in the screenshot the view and editor fonts are all serif fonts, which makes it hard to read - especially when zoomed out. The font also consumes a lot of space. I would like to change the font to a sans-serif font, and be able to make the size smaller. My monitor has a low resolution, and i want to be able to cram more text into my view
Thank you
Hi atle,
Thanks for your screenshot. I’ve forwarded the details to our engineers to follow up. Once there is any feedback, I’ll come back to you immediately.
Hi atle,
For the font issue, it seems that you are using an old version. We’ve already changed to Sans-Serif in our application.
And for the size of font, we’ve fixed the large font size (in menu as well as in tree) to be normal size. You can download the latest patch at the link below and see if the problem is solved.
http://files3.visual-paradigm.com/200805/Patch/sp1_20080417ze/VP_Suite_Linux_3_2_sp1_20080417ze.sh
To use the patch:
Note: This patch is made for VP Suite 3.2 SP1 (VP-UML 6.2 SP1). Please make sure you have a valid product license. Otherwise you won’t be able to startup the product after the installation.
If you have any questions, please feel free to contact me again.
I downloaded and started the latest version. It seems like the fonts are changed, but it takes over 30 minutes to start. I have filed a report, but havent gotten any answer yet.
My system:
Latest SDE (downloaded from link above)
OpenJDK 6
Kubuntu / Linux
I use floating licence server. After about 30 minutes i get to the confiugration of the license dialog, and testing the connection returns success. I have no network problems, and the eclipse process seems pretty idle. I can only guess that it has something to do with my upgrade to OpenJDK…
One more comment: Eclipse itself loads in a few seconds, it is the loading of the SDE that takes time.
Hi atle,
Thanks for your details. Could you please send me the following files for investigation? Thanks in advance!
Looking forward to your reply.
Here is the eclipse config
*** Date: Tuesday, May 13, 2008 8:06:08 AM Norway
*** Platform Details:
*** System properties:
eclipse.buildId=M20080221-1800
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-showsplash
/home/prange/dev/tools/modelling/eclipse//plugins/org.eclipse.platform_3.3.3.r33x_r20080129/splash.bmp
-launcher
/home/prange/dev/tools/modelling/eclipse/eclipse
-name
Eclipse
–launcher.library
/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.0.3.R33x_v20080118/eclipse_1023.so
-startup
/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.launcher_1.0.1.R33x_v20080118.jar
-vm
/usr/lib/jvm/java-6-openjdk/jre/bin/…/lib/i386/client/libjvm.so
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1210656497986
eclipse.vm=/usr/lib/jvm/java-6-openjdk/jre/bin/…/lib/i386/client/libjvm.so
eclipse.vmargs=-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-Djava.class.path=/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.launcher_1.0.1.R33x_v20080118.jar
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.version=50.0
java.endorsed.dirs=/usr/lib/jvm/java-6-openjdk/jre/lib/endorsed
java.ext.dirs=/usr/lib/jvm/java-6-openjdk/jre/lib/ext:/usr/java/packages/lib/ext
java.home=/usr/lib/jvm/java-6-openjdk/jre
java.io.tmpdir=/tmp
java.library.path=/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client::/usr/lib/jvm/java-6-openjdk/jre/lib/i386::/usr/lib/xulrunner-addons:/usr/lib/xulrunner-addons:/usr/java/packages/lib/i386:/lib:/usr/lib
java.runtime.name=OpenJDK Runtime Environment
java.runtime.version=1.6.0-b09
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0
java.vm.info=mixed mode, sharing
java.vm.name=OpenJDK Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.6.0-b09
javax.accessibility.assistive_technologies=org.GNOME.Accessibility.JavaBridge
javax.net.ssl.trustStore=/etc/ssl/certs/ca-certificates.crt
javax.net.ssl.trustStorePassword=
javax.net.ssl.trustStoreProvider=
javax.net.ssl.trustStoreType=CertBundle
line.separator=
org.eclipse.equinox.launcher.splash.location=/home/prange/dev/tools/modelling/eclipse//plugins/org.eclipse.platform_3.3.3.r33x_r20080129/splash.bmp
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.24-16-generic
org.osgi.framework.processor=i386
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views ,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=/home/prange/dev/tools/modelling/eclipse/configuration/org.eclipse.osgi/bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/home/prange/dev/tools/modelling/eclipse/configuration/
osgi.framework=file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.osgi_3.3.2.R33x_v20080105.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.2.R33x_v20080105
osgi.install.area=file:/home/prange/dev/tools/modelling/eclipse/
osgi.instance.area=file:/home/prange/dev/modelling-workspace/
osgi.instance.area.default=file:/home/prange/workspace/
osgi.logfile=/home/prange/dev/modelling-workspace/.metadata/.log
osgi.manifest.cache=/home/prange/dev/tools/modelling/eclipse/configuration/org.eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.splashLocation=/home/prange/dev/tools/modelling/eclipse//plugins/org.eclipse.platform_3.3.3.r33x_r20080129/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/home/prange/dev/tools/modelling/eclipse/plugins
osgi.ws=gtk
path.separator=:
proxySet=false
sun.arch.data.model=32
sun.awt.noerasebackground=true
sun.boot.class.path=/usr/lib/jvm/java-6-openjdk/jre/lib/resources.jar:/usr/lib/jvm/java-6-openjdk/jre/lib/rt.jar:/usr/lib/jvm/java-6-openjdk/jre/lib/sunrsasign.jar:/usr/lib/jvm/java-6-openjdk/jre/lib/jsse.jar:/usr/lib/jvm/java-6-openjdk/jre/lib/jce.jar:/usr/lib/jvm/java-6-openjdk/jre/lib/charsets.jar:/usr/lib/jvm/java-6-openjdk/jre/classes
sun.boot.library.path=/usr/lib/jvm/java-6-openjdk/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/home/prange
user.home=/home/prange
user.language=en
user.name=prange
user.timezone=Europe/Oslo
user.zoneinfo.dir=/usr/share/javazi
*** Features:
org.eclipse.cvs (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_) “Eclipse CVS Client”
org.eclipse.cvs.source (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_) “Eclipse CVS Client SDK”
org.eclipse.jdt (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7) “Eclipse Java Development Tools”
org.eclipse.jdt.source (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7) “Eclipse Java Development Tools SDK”
org.eclipse.pde (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL) “Eclipse Plug-in Development Environment”
org.eclipse.pde.source (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL) “Eclipse Plug-in Development Environment Developer Resources”
org.eclipse.platform (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft) “Eclipse Platform”
org.eclipse.platform.source (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft) “Eclipse Platform Plug-in Developer Resources”
org.eclipse.rcp (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc) “Eclipse RCP”
org.eclipse.rcp.source (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc) “Eclipse RCP Plug-in Developer Resources”
org.eclipse.sdk (3.3.3.r33x_r20080129-7M7J7LB-u3aphGW6o3_VmiVfGXWO) “Eclipse Project SDK”
*** Plug-in Registry:
com.ibm.icu (3.6.1.v20070906) “International Components for Unicode for Java (ICU4J)” [Active]
com.ibm.icu.source (3.6.1.v20070906) “International Components for Unicode for Java (ICU4J) source plug-in” [Resolved]
com.jcraft.jsch (0.1.31) “JSch” [Resolved]
com.vp.vpsde.ec (4.2.0.0) “Smart Development Environment for Eclipse” [Active]
javax.servlet (2.4.0.v200706111738) “Servlet API Bundle” [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) “Java Server Pages API Bundle” [Resolved]
javax.servlet.jsp.source (2.0.0.v200706191603) “Java Server Pages API Source Bundle” [Resolved]
javax.servlet.source (2.4.0.v200706111738) “Servlet API Source Bundle” [Resolved]
org.apache.ant (1.7.0.v200706080842) “Apache Ant” [Resolved]
org.apache.ant.source (1.7.0.v200706080842) “Apache Ant Source” [Resolved]
org.apache.commons.el (1.0.0.v200706111724) “Apache Commons JSP 2.0 Expression Language Interpreter” [Resolved]
org.apache.commons.el.source (1.0.0.v200706111724) “Apache Commons JSP 2.0 Expression Language Interpreter Source” [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) “Apache Commons Logging Plug-in” [Resolved]
org.apache.commons.logging.source (1.0.4.v200706111724) “Apache Commons Logging Plug-in Source” [Resolved]
org.apache.jasper (5.5.17.v200706111724) “Apache Jasper 2 Plug-in” [Resolved]
org.apache.jasper.source (5.5.17.v200706111724) “Apache Jasper 2 Source Plug-in” [Resolved]
org.apache.lucene (1.9.1.v200706111724) “Apache Lucene” [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) “Apache Lucene Analysis” [Resolved]
org.apache.lucene.analysis.source (1.9.1.v200706181610) “Apache Lucene Analysis Source” [Resolved]
org.apache.lucene.source (1.9.1.v200706111724) “Apache Lucene Source” [Resolved]
org.eclipse.ant.core (3.1.200.v20070522) “Ant Build Tool Core” [Starting]
org.eclipse.ant.ui (3.2.200.v20070825_r331) “Ant UI” [Starting]
org.eclipse.compare (3.3.2.r33x_20080128) “Compare Support” [Starting]
org.eclipse.core.boot (3.1.100.v20060603) “Core Boot” [Starting]
org.eclipse.core.commands (3.3.0.I20070605-0010) “Commands” [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) “Eclipse Content Mechanism” [Active]
org.eclipse.core.databinding (1.0.1.M20070822-0800) “JFace Data Binding” [Resolved]
org.eclipse.core.databinding.beans (1.0.1.M20070910-0800b) “JFace Data Binding for JavaBeans” [Resolved]
org.eclipse.core.expressions (3.3.0.v20070606-0010) “Expression Language” [Active]
org.eclipse.core.filebuffers (3.3.1.r331_v20070829) “File Buffers” [Active]
org.eclipse.core.filesystem (1.1.0.v20070606) “Core File Systems” [Active]
org.eclipse.core.filesystem.linux.x86 (1.1.0.v20070416) “Core File System for Linux” [Resolved]
org.eclipse.core.jobs (3.3.1.R33x_v20070709) “Eclipse Jobs Mechanism” [Active]
org.eclipse.core.net (1.0.1.r33x_20070709) “Internet Connection Management” [Active]
org.eclipse.core.resources (3.3.1.R33x_v20080205) “Core Resource Management” [Active]
org.eclipse.core.resources.compatibility (3.2.100.v20070502) “Core Resource Management Compatibility Fragment” [Resolved]
org.eclipse.core.runtime (3.3.100.v20070530) “Core Runtime” [Active]
org.eclipse.core.runtime.compatibility (3.1.200.v20070502) “Core Runtime Plug-in Compatibility” [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502) “Authorization Compatibility Plug-in” [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316) “Eclipse Registry Compatibility Fragment” [Resolved]
org.eclipse.core.variables (3.2.0.v20070426) “Core Variables” [Starting]
org.eclipse.cvs (1.0.2.r33x_r20080129) “Eclipse CVS Client” [Starting]
org.eclipse.cvs.source (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_) “Eclipse CVS Client SDK” [Resolved]
org.eclipse.debug.core (3.3.2.v20080117_r332) “Debug Core” [Active]
org.eclipse.debug.ui (3.3.2.v20080117_r332) “Debug UI” [Active]
org.eclipse.equinox.app (1.0.1.R33x_v20070828) “Equinox Application Container” [Active]
org.eclipse.equinox.common (3.3.0.v20070426) “Common Eclipse Runtime” [Active]
org.eclipse.equinox.http.jetty (1.0.1.R33x_v20070816) “Jetty Http Service” [Starting]
org.eclipse.equinox.http.registry (1.0.1.R33x_v20071231) “Http Service Registry Extensions” [Resolved]
org.eclipse.equinox.http.servlet (1.0.1.R33x_v20070816) “Http Services Servlet” [Starting]
org.eclipse.equinox.jsp.jasper (1.0.1.R33x_v20070816) “Jasper Jsp Support Bundle” [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) “Jasper Jsp Registry Support Plug-in” [Starting]
org.eclipse.equinox.launcher (1.0.1.R33x_v20080118) “Equinox Launcher” [Resolved]
org.eclipse.equinox.launcher.gtk.linux.x86 (1.0.3.R33x_v20080118) “Equinox Launcher Linux X86 Fragment” [Resolved]
org.eclipse.equinox.preferences (3.2.101.R33x_v20080117) “Eclipse Preferences Mechanism” [Active]
org.eclipse.equinox.registry (3.3.1.R33x_v20070802) “Extension Registry Support” [Active]
org.eclipse.help (3.3.2.v20071126_33x) “Help System Core” [Active]
org.eclipse.help.appserver (3.1.200.v20070510) “Help Application Server” [Starting]
org.eclipse.help.base (3.3.1.v20070813_33x) “Help System Base” [Starting]
org.eclipse.help.ui (3.3.2.v20071126_33x) “Help System UI” [Starting]
org.eclipse.help.webapp (3.3.2.v20071102_33x) “Help System Webapp” [Starting]
org.eclipse.jdt (3.3.1.r332_v20080131) “Eclipse Java Development Tools” [Resolved]
org.eclipse.jdt.apt.core (3.3.1.R33x_v20071112-2330) “Java Annotation Processing Core” [Starting]
org.eclipse.jdt.apt.pluggable.core (1.0.1.R33x_v20071002-2100) “Java Compiler Apt IDE” [Starting]
org.eclipse.jdt.apt.ui (3.3.1.R33x_v20071002-2100) “Java Annotation Processing UI” [Starting]
org.eclipse.jdt.compiler.apt (1.0.1.R33x_v20071002-2100) “Java Compiler Apt” [Resolved]
org.eclipse.jdt.compiler.tool (1.0.1.v_793_R33x) “Java Compiler Tool Support” [Resolved]
org.eclipse.jdt.core (3.3.3.v_793_R33x) “Java Development Tools Core” [Active]
org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) “Java Code Manipulation Functionality” [Active]
org.eclipse.jdt.debug (3.3.1.v20070719_r331) “JDI Debug Model” [Starting]
org.eclipse.jdt.debug.ui (3.2.102.v20071002_r332) “JDI Debug UI” [Starting]
org.eclipse.jdt.doc.isv (3.3.1.r331_v20070913) “Eclipse JDT Plug-in Developer Guide” [Starting]
org.eclipse.jdt.doc.user (3.3.2.r332_20080116-0900) “Eclipse Java Development User Guide” [Starting]
org.eclipse.jdt.junit (3.3.2.r332_20080109-0800) “Java Development Tools JUnit support” [Starting]
org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) “Java Development Tools JUnit runtime support” [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) “Java Development Tools JUnit4 runtime support” [Resolved]
org.eclipse.jdt.launching (3.3.2.v20080115_r332) “Java Development Tools Launching Support” [Starting]
org.eclipse.jdt.source (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7) “Eclipse Java Development Tools SDK” [Resolved]
org.eclipse.jdt.ui (3.3.2.r332_20080128) “Java Development Tools UI” [Active]
org.eclipse.jface (3.3.2.M20080207-0800) “JFace” [Active]
org.eclipse.jface.databinding (1.1.1.M20080207-0800) “JFace Data Binding for SWT and JFace” [Resolved]
org.eclipse.jface.text (3.3.2.r332_20071017-0800) “JFace Text” [Resolved]
org.eclipse.jsch.core (1.0.0.I20070426) “JSch Core” [Starting]
org.eclipse.jsch.ui (1.0.1.r33x_20070709) “JSch UI” [Starting]
org.eclipse.ltk.core.refactoring (3.3.1.r332_20080128) “Refactoring Core” [Starting]
org.eclipse.ltk.ui.refactoring (3.3.1.r332_20080128) “Refactoring UI” [Starting]
org.eclipse.osgi (3.3.2.R33x_v20080105) “OSGi System Bundle” [Active]
org.eclipse.osgi.services (3.1.200.v20070605) “OSGi Release 4.0.1 Services” [Resolved]
org.eclipse.osgi.util (3.1.200.v20070605) “OSGi Release 4.0.1 Utility Classes” [Resolved]
org.eclipse.pde (3.3.1.r33x_r20080129) “Eclipse Plug-in Development Environment” [Resolved]
org.eclipse.pde.build (3.3.2.v20071019) “Plug-in Development Environment Build Support” [Starting]
org.eclipse.pde.core (3.3.2.v20071121-0800) “Plug-in Development Core” [Starting]
org.eclipse.pde.doc.user (3.3.0.v20070614-0800) “Eclipse Plug-in Development User Guide” [Resolved]
org.eclipse.pde.junit.runtime (3.3.0.v20070608-1300) “PDE JUnit Plug-in Test” [Resolved]
org.eclipse.pde.runtime (3.3.0.v20070608-1300) “Plug-in Development Environment Runtime” [Starting]
org.eclipse.pde.source (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL) “Eclipse Plug-in Development Environment Developer Resources” [Resolved]
org.eclipse.pde.ui (3.3.1.v20070912-0800) “Plug-in Development UI” [Starting]
org.eclipse.pde.ui.templates (3.3.0.v20070608-1300) “PDE Templates” [Starting]
org.eclipse.platform (3.3.3.r33x_r20080129) “Eclipse Platform” [Starting]
org.eclipse.platform.doc.isv (3.3.1.r331_v20070913) “Eclipse Platform Plug-in Developer Guide” [Starting]
org.eclipse.platform.doc.user (3.3.0.M20070913-1400) “Eclipse Workbench User Guide” [Starting]
org.eclipse.platform.source (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft) “Eclipse Platform Plug-in Developer Resources” [Resolved]
org.eclipse.platform.source.linux.gtk.x86 (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft) “Eclipse Platform Plug-in Developer Resources” [Resolved]
org.eclipse.rcp (3.2.1.r33x_r20080131) “Eclipse RCP” [Starting]
org.eclipse.rcp.source (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc) “Eclipse RCP Plug-in Developer Resources” [Resolved]
org.eclipse.rcp.source.linux.gtk.x86 (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc) “Eclipse RCP Plug-in Developer Resources” [Resolved]
org.eclipse.sdk (3.3.3.r33x_r20080129) “Eclipse Project SDK” [Starting]
org.eclipse.search (3.3.1.r331_v20070831-0800) “Search Support” [Starting]
org.eclipse.swt (3.3.2.v3349d) “Standard Widget Toolkit” [Resolved]
org.eclipse.swt.gtk.linux.x86 (3.3.2.v3349) “Standard Widget Toolkit for GTK 2.0” [Resolved]
org.eclipse.team.core (3.3.1.r33x_20080128) “Team Support Core” [Active]
org.eclipse.team.cvs.core (3.3.2.r33x_20080128) “CVS Team Provider Core” [Starting]
org.eclipse.team.cvs.ssh (3.2.100.I20061208) “CVS SSH Core” [Starting]
org.eclipse.team.cvs.ssh2 (3.2.100.I20070604) “CVS SSH2” [Starting]
org.eclipse.team.cvs.ui (3.3.1.r33x_20070807) “CVS Team Provider UI” [Starting]
org.eclipse.team.ui (3.3.2.r33x_20080128) “Team Support UI” [Starting]
org.eclipse.text (3.3.0.v20070606-0010) “Text” [Resolved]
org.eclipse.tomcat (4.1.230.v20070531) “Tomcat Wrapper” [Starting]
org.eclipse.ui (3.3.1.M20071128-0800) “Eclipse UI” [Active]
org.eclipse.ui.browser (3.2.100.v20070524A) “Browser Support” [Starting]
org.eclipse.ui.cheatsheets (3.3.1.v20080125_33x) “Cheat Sheets” [Starting]
org.eclipse.ui.console (3.2.2.v20071031_r332) “Console” [Starting]
org.eclipse.ui.editors (3.3.2.r332_20080109-0800) “Default Text Editor” [Active]
org.eclipse.ui.externaltools (3.1.200.v20070416) “External Tools” [Active]
org.eclipse.ui.forms (3.3.0.v20070511) “Eclipse Forms” [Starting]
org.eclipse.ui.ide (3.3.2.M20080207-0800) “Eclipse IDE UI” [Active]
org.eclipse.ui.ide.application (1.0.0.I20070530-0100) “Eclipse IDE UI Application” [Resolved]
org.eclipse.ui.intro (3.2.101.v20070827_33x) “Welcome Framework” [Starting]
org.eclipse.ui.intro.universal (3.2.100.v20070530A) “Universal Welcome” [Starting]
org.eclipse.ui.navigator (3.3.2.M20080207-0800) “Common Navigator View” [Starting]
org.eclipse.ui.navigator.resources (3.3.1.M20070831-2000) “Navigator Workbench Components” [Starting]
org.eclipse.ui.net (1.0.0.I20070516) “Internet Connection Management UI” [Active]
org.eclipse.ui.presentations.r21 (3.2.100.I20070605-0010) “R21 Presentation Plug-in” [Starting]
org.eclipse.ui.views (3.2.101.M20080207-0800) “Views” [Active]
org.eclipse.ui.views.properties.tabbed (3.3.1.M20070831-0800) “Tabbed Properties View” [Starting]
org.eclipse.ui.workbench (3.3.2.M20080207-0800) “Workbench” [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20070319-0010) “Workbench Compatibility” [Resolved]
org.eclipse.ui.workbench.texteditor (3.3.2.r332_20080109-0800) “Text Editor Framework” [Active]
org.eclipse.update.configurator (3.2.101.R33x_v20070810) “Install/Update Configurator” [Active]
org.eclipse.update.core (3.2.101.R33x_v20070911) “Install/Update Core” [Active]
org.eclipse.update.core.linux (3.2.0.v20070615) “Install/Update Core for Linux” [Resolved]
org.eclipse.update.scheduler (3.2.100.v20070615) “Automatic Updates Scheduler” [Active]
org.eclipse.update.ui (3.2.100.v20070615) “Install/Update UI” [Starting]
org.junit (3.8.2.v200706111738) “JUnit Testing Framework” [Resolved]
org.junit.source (3.8.2.v200706111738) “JUnit Testing Framework Source” [Resolved]
org.junit4 (4.3.1) “JUnit Testing Framework Version 4” [Resolved]
org.mortbay.jetty (5.1.11.v200706111724) “Jetty WebServer” [Resolved]
org.mortbay.jetty.source (5.1.11.v200706111724) “Jetty WebServer Source” [Resolved]
*** User Preferences:
#Tue May 13 08:06:08 CEST 2008
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAUNCH_PERSPECTIVES=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\n\n
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.width=
/instance/org.eclipse.ui.ide/platformState=1210331542765
file_export_version=3.0
@org.eclipse.jdt.ui=3.3.2.r332_20080128
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.net=1.0.1.r33x_20070709
@org.eclipse.jdt.launching=3.3.2.v20080115_r332
/instance/org.eclipse.jdt.ui/spelling_locale_initialized=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.source=1.6
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.compliance=1.6
@org.eclipse.debug.ui=3.3.2.v20080117_r332
/instance/org.eclipse.ui/showIntro=false
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.jdt.core=3.3.3.v_793_R33x
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=/home/prange/dev/modelling-workspace\n/home/prange/workspace
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=false
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.assertIdentifier=error
@org.eclipse.ui.ide=3.3.2.M20080207-0800
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder.resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.jdt.ui/fontPropagated=true
@org.eclipse.core.resources=3.3.1.R33x_v20080205
@org.eclipse.ui=3.3.1.M20071128-0800
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launching.PREF_VM_XML=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\n<vmSettings defaultVM=“57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType13,1209470494309”>\n<vmType id=“org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType”>\n<vm id=“1209470494309” javadocURL=“http://java.sun.com/javase/6/docs/api/” name=“java-6-openjdk” path=“/usr/lib/jvm/java-6-openjdk”/>\n\n\n
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=3
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.enumIdentifier=error
@org.eclipse.ui.editors=3.3.2.r332_20080109-0800
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocations.migrated=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterprofiles.version=11
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.targetPlatform=1.6
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Monospace|10.0|0|GTK|1|;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.inlineJsrBytecode=enabled
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
*** Current Install Configuration:
Install configuration:
Last changed on May 9, 2008
Location: file:/home/prange/dev/tools/modelling/eclipse/configuration/org.eclipse.update/platform.xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.sdk, Version: 3.3.3.r33x_r20080129-7M7J7LB-u3aphGW6o3_VmiVfGXWO
ID: org.eclipse.cvs.source, Version: 1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_
ID: org.eclipse.jdt.source, Version: 3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7
ID: org.eclipse.rcp.source, Version: 3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc
ID: org.eclipse.pde.source, Version: 3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL
ID: org.eclipse.platform, Version: 3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft
ID: org.eclipse.platform.source, Version: 3.3.3.r33x_r20080129-19UEl7Ezk_gXF1kouft
ID: org.eclipse.rcp, Version: 3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc
ID: org.eclipse.pde, Version: 3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL
ID: org.eclipse.cvs, Version: 1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L
ID: org.eclipse.jdt, Version: 3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7
Configured plug-ins:
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.help.base_3.3.1.v20070813_33x.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.filesystem.linux.x86_1.1.0.v20070416.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.commands_3.3.0.I20070605-0010.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2.100.I20070604.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/com.ibm.icu.source_3.6.1.v20070906/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jface.databinding_1.1.1.M20080207-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.junit4_4.3.1/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.launching_3.3.2.v20080115_r332.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20070319-0010/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.platform.source_3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft/
file:/home/prange/dev/tools/modelling/eclipse/plugins/javax.servlet.jsp_2.0.0.v200706191603.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.http.jetty_1.0.1.R33x_v20070816.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.net_1.0.0.I20070516.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/com.ibm.icu_3.6.1.v20070906.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.workbench_3.3.2.M20080207-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.core.manipulation_1.1.0.v20070606-0010.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.databinding_1.0.1.M20070822-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.platform.source.linux.gtk.x86_3.3.3.r33x_r20080129-19UEl7Ezk_gXF1kouft/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.resources.compatibility_3.2.100.v20070502.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.app_1.0.1.R33x_v20070828.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.cvs_1.0.2.r33x_r20080129.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.platform.doc.user_3.3.0.M20070913-1400.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.team.ui_3.3.2.r33x_20080128.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.3.2.r332_20080109-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jsch.ui_1.0.1.r33x_20070709.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.jsp.jasper_1.0.1.R33x_v20070816.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.lucene.analysis.source_1.9.1.v200706181610/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.3.1.r332_20080128.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.ant_1.7.0.v200706080842/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.junit_3.8.2.v200706111738/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.jsp.jasper.registry_1.0.0.v20070607.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.junit.runtime_3.3.0.v20070606-0010.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.ant.source_1.7.0.v200706080842/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.boot_3.1.100.v20060603.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.update.core.linux_3.2.0.v20070615.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.pde.ui.templates_3.3.0.v20070608-1300.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jface.text_3.3.2.r332_20071017-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.update.scheduler_3.2.100.v20070615.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.pde.source_3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.swt_3.3.2.v3349d.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.mortbay.jetty_5.1.11.v200706111724.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.update.configurator_3.2.101.R33x_v20070810.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.debug.core_3.3.2.v20080117_r332.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.filesystem_1.1.0.v20070606.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.mortbay.jetty.source_5.1.11.v200706111724/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.runtime.compatibility.auth_3.2.100.v20070502.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.lucene.source_1.9.1.v200706111724/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.help.ui_3.3.2.v20071126_33x.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.junit_3.3.2.r332_20080109-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.jasper.source_5.5.17.v200706111724/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.runtime_3.3.100.v20070530.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.apt.core_3.3.1.R33x_v20071112-2330.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui_3.3.1.M20071128-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.debug_3.3.1.v20070719_r331/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.lucene_1.9.1.v200706111724.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.debug.ui_3.3.2.v20080117_r332.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.filebuffers_3.3.1.r331_v20070829.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.lucene.analysis_1.9.1.v200706181610.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/com.jcraft.jsch_0.1.31.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.registry_3.3.1.R33x_v20070802.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt_3.3.1.r332_v20080131.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.apt.ui_3.3.1.R33x_v20071002-2100.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.pde.ui_3.3.1.v20070912-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.console_3.2.2.v20071031_r332.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.cheatsheets_3.3.1.v20080125_33x.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.compare_3.3.2.r33x_20080128.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.debug.ui_3.2.102.v20071002_r332.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.navigator_3.3.2.M20080207-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.intro_3.2.101.v20070827_33x.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.team.core_3.3.1.r33x_20080128.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.databinding.beans_1.0.1.M20070910-0800b.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.runtime.compatibility_3.1.200.v20070502.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/com.vp.sde.eclipse_4.2.0.0/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.externaltools_3.1.200.v20070416.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.rcp_3.2.1.r33x_r20080131.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.platform.doc.isv_3.3.1.r331_v20070913.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.views.properties.tabbed_3.3.1.M20070831-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ant.ui_3.2.200.v20070825_r331.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.runtime.compatibility.registry_3.2.100.v20070316/
file:/home/prange/dev/tools/modelling/eclipse/plugins/javax.servlet.jsp.source_2.0.0.v200706191603/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.osgi.util_3.1.200.v20070605.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.compiler.tool_1.0.1.v_793_R33x.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.pde.junit.runtime_3.3.0.v20070608-1300.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.http.servlet_1.0.1.R33x_v20070816.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.commons.el_1.0.0.v200706111724.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/javax.servlet_2.4.0.v200706111738.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.apt.pluggable.core_1.0.1.R33x_v20071002-2100.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.editors_3.3.2.r332_20080109-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.pde.core_3.3.2.v20071121-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.tomcat_4.1.230.v20070531/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.preferences_3.2.101.R33x_v20080117.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.update.ui_3.2.100.v20070615.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ant.core_3.1.200.v20070522.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.search_3.3.1.r331_v20070831-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.pde.build_3.3.2.v20071019/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.rcp.source_3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.help.webapp_3.3.2.v20071102_33x.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.ide_3.3.2.M20080207-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.text_3.3.0.v20070606-0010.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jsch.core_1.0.0.I20070426.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.doc.user_3.3.2.r332_20080116-0900.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.cvs.source_1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.commons.el.source_1.0.0.v200706111724/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.doc.isv_3.3.1.r331_v20070913.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.variables_3.2.0.v20070426.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.help.appserver_3.1.200.v20070510.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.jasper_5.5.17.v200706111724.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.net_1.0.1.r33x_20070709.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.sdk_3.3.3.r33x_r20080129/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.ui_3.3.2.r332_20080128.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.help_3.3.2.v20071126_33x.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.browser_3.2.100.v20070524A.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.pde.runtime_3.3.0.v20070608-1300.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.navigator.resources_3.3.1.M20070831-2000.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.core_3.3.3.v_793_R33x.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.team.cvs.ui_3.3.1.r33x_20070807.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.rcp.source.linux.gtk.x86_3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.update.core_3.2.101.R33x_v20070911.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.swt.gtk.linux.x86_3.3.2.v3349.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.compiler.apt_1.0.1.R33x_v20071002-2100.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.osgi.services_3.1.200.v20070605.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.expressions_3.3.0.v20070606-0010.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.presentations.r21_3.2.100.I20070605-0010.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.resources_3.3.1.R33x_v20080205.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.contenttype_3.2.100.v20070319.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.3.1.r332_20080128.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.pde.doc.user_3.3.0.v20070614-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.common_3.3.0.v20070426.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.http.registry_1.0.1.R33x_v20071231.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.views_3.2.101.M20080207-0800.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.core.jobs_3.3.1.R33x_v20070709.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.source_3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.junit.source_3.8.2.v200706111738/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.team.cvs.ssh_3.2.100.I20061208.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.commons.logging_1.0.4.v200706111724.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.pde_3.3.1.r33x_r20080129.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jdt.junit4.runtime_1.0.100.v20070606-0010.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/javax.servlet.source_2.4.0.v200706111738/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.forms_3.3.0.v20070511.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.0.3.R33x_v20080118/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.equinox.launcher_1.0.1.R33x_v20080118.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.team.cvs.core_3.3.2.r33x_20080128.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.apache.commons.logging.source_1.0.4.v200706111724/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.ide.application_1.0.0.I20070530-0100.jar
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.platform_3.3.3.r33x_r20080129/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.ui.intro.universal_3.2.100.v20070530A/
file:/home/prange/dev/tools/modelling/eclipse/plugins/org.eclipse.jface_3.3.2.M20080207-0800.jar
no_name.log
vp.log
I just had time to start SDE, the font is still Serif (like on the screenshot)
Hi Atle,
Thanks for the details. Could you also send the vp.log and the eclipse log file for diagnosing your problem? Thanks a lot!
FYI, the vp.log file is inside eclipse folder and the .log file is inside $eclipse-workspace/.metadata folder.
For the font issue, I’ve passed to our engineers to have a further investigation. If there is any feedback, I’ll come back to you at once.
Hi Atle,
For the font issue in SE-EC, we’ve deployed a build that should solve your problem. Please download the patch in the link below and see if it works fine. If there is any problem, please let me know.
http://files3.visual-paradigm.com/200805/Patch/sp1_20080513e/VP_Suite_Linux_3_2_sp1_20080513e.sh
We hope we will help in solving the issue of starup time of SDE-EC as well. Looking forward to you response and the log file of eclipse, vp.log file from you. Thanks!
Hi, the log files are attached to the same message above that contains the eclipse config information (you have to scroll to the right on the forum to see the attachments…)
I will test the new version now.
Hi Atle,
Thanks you for your reply and I’m sorry that I did not notice the attached files before. I’ve passed the issue and the files to our engineers to investigate, and I’ll notify you with any feedback about the issue.
By the meantime, if you have any questions, please do not hesitate to ask.
The font issue is fixed, very good. Alas the tool still takes ages to start up. I hope my log files clear things up…
Hi Atle,
Thanks for your try on the latest build and I’m glad that it solves the font problem.
Our engineers are investigating your starting time problem, and I’m come back to you immediately once there is any feedback.
Hi Atle,
regarding to the startup time of SDE-EC, you’ve mentioned that
"I can only guess that it has something to do with my upgrade to OpenJDK…"
Does this mean that you did not have any time problem on starting SDE-EC with old OpenJDK? If yes, could you please tell me the versions of the old OpenJDK you used? Thanks in advance!
Hi, i am not certain of anything here, but the slowdown happened after i upgraded to kubuntu 8.04. The only difference i know of concerning java is that the new kubuntu has OpenJDK installed, and the previous version had the “standard” sun JDK 1.6. There might of course be other changes i am unaware of, maybe in the networking area. I am actually quite puzzled, because the CPU useage is very low during the startup (so no infinite loops), but there is progress (no deadlock). Maybe there are lot of threads that hang on long timeouts? (I am just guessing wildly).
Hi Atle,
Thanks for your kindly help by the detail information, I’ve forwarded the details to our engineers for further investigation. I’ll keep you informed for any feedback for this issue.
Have a nice day!
