Hi!
Can I create for naming Foreign Key (which also is PK) by follow pattern: “ID_{class_name}”? Now Foreign Key which also is PK naming as “simple” FK…
TIA, Eugeny
Hi Eugeny,
Thanks for your post. Do you mean you want to configure the name pattern of column that is FK+PK?
Yes, I want to configure FK+PK pattern.
Hi Eugeny,
Thanks for replying but I’m sorry that configuration of naming pattern of FK+PK is not supported, but we will consider this. I’ll let you know once there is any news on this issue.
Thanks a lot!
Hi Eugeny,
You are welcome.
Hi Eugeny,
I would like to confirm with you that:
- Do you actually want to have specific naming pattern ONLY for FK+PK column (i.e. there are 3 separate naming pattern for FK, PK, FK+PK)?
- If it’s yes to point 1, is it acceptable that once you configure the FK+PK naming pattern, the name of any column becomes FK+PK will be automatically changed to the configured pattern?
Thanks and I look forward to hearing your response.
Hi, Lilian!
I think that:
- Yes
- Yes
TIA, Eugeny
Hi Eugney,
Thanks and I’ve passed to our engineers to follow-up. I’ll let you know once there is any further news.
