hello,
I can conect to the database, but cant generate anything, it always opens a blank window. i also get an error when i do refresh.
in the log file there are some null-pointer-exceptions.
does anybody know what i can do?
thanks
Theo
hello,
thanks
Theo
Hi Theo,
Thank you for your post. Would you mind showing me some screenshots about the problem? Also, could you post the log here so that our developers could check what the problem is? Thank you in advance!
hello,
the problem disappeared when I installed DB Visual Architect.
I am using the mySql server version: 5.0.24a-community-nt
I can post a part of the log so you an find the problem:
Mon Sep 18 17:39:43 CEST 2006] [warning] No JNI Library 8
Mon Sep 18 17:42:30 CEST 2006] [message] Exception in thread "AWT-EventQueue-0"
Mon Sep 18 17:42:30 CEST 2006] [message] java.lang.NullPointerException
Mon Sep 18 17:42:30 CEST 2006] [message] at v.iofl.i(:1019)
Mon Sep 18 17:42:30 CEST 2006] [message] at v.iofl.i(:34)
Mon Sep 18 17:42:30 CEST 2006] [message] at v.itd.actionPerformed(:1001)
Mon Sep 18 17:42:30 CEST 2006] [message] at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at javax.swing.AbstractButton.doClick(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.Component.processMouseEvent(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at javax.swing.JComponent.processMouseEvent(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.Component.processEvent(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.Container.processEvent(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.Component.dispatchEventImpl(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.Container.dispatchEventImpl(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.Component.dispatchEvent(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.Window.dispatchEventImpl(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.EventQueue.dispatchEvent(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
Mon Sep 18 17:42:30 CEST 2006] [message] at java.awt.EventDispatchThread.run(Unknown Source)
thanks
Theodor
Hi tgrip,
Thanks a lot for the log contents. Could you post the log file instead of part of its content? This is because the log file may contain useful information such as build number, which is important for us to locate the problem region. Thank you!
Hello Theodor,
Is this problem the same as the one you posted in the DBVA forum?
http://forums.visual-paradigm.com/posts/list/1637.html#5970
hello,
I think the problem is similar, but it is not the same. I am using the same database, but this problem was resolved with the instalation of DBVA, while the other problem remains that I can not generate the classes.
best regards
Theodor
Hi tgrip,
You said that the problem was resolved with the installation of DBVA. May I know what product caused the problem before? Was it the old version of DBVA, or another product?
Also, I notice that you haven’t mention whether you were trying to generate database or code. Could you clarify? Thank you.
hello,
sorry, my message was a little bit confusing. I have used DB-VA SQL before, and the problem was resolved with DB Visual Architect.
The code generation problem refered to the DB Visual Architect.
thanks
Theodor
Hello Theodor,
Thanks for clairfying the problem. I answered another message sent from you at:
http://forums.visual-paradigm.com/posts/list/0/1637.html#5987
Could you check that out and let me know if the steps can solve this problem as well? Thank you very much!
