We’re using Visual Paradigm with java language.
In our model, every object has a base class and implements interfaces (which also have base interface as well).
So the model looks like this:
BaseInterface —> InterfaceA ----> ClassA (realisation)
BaseClass ----> ClassA (generalisation) (class ClassA extends BaseClass implements InterfaceA)
1. Problem and Question
Right now I can only implement this model this way: BaseClass is part of the diagram, and every new Class in the model has a generalisation connection to the BaseClass. This gives a graphically ugly diagram, where every model object has a connection line to the Base class.
If I remove the BaseClass from the diagram, the connection lines dissapear, and the generalisation can be seen in the relation table correctly.
Questin: is it possible, to add Classes to the model, where a Class has generalisation to a base class, but that base class is NOT part of the specific diagram?
2. Problem and Question
With the model described above, I would like to define new pattern.
If I define a pattern where a class extends a base class I have two options:
Including the base class in the pattern definition:
This way when I create new classes based on this pattern, the pattern creates new base class every time.
(for examle BaseClass becomes BaseClass, BaseClass1, BaseClass2 etc.) -
Excluding the base class from the pattern definition:
This way when I create new classes based on this pattern, the new classes doesn’t have generalisation relations at all.
Question: How can I define such a pattern, telling that every new class has to extend a (specific well defined) base class, and implement an interface which extends a (specific well defined) base interface?
Thank you in advance:
Gejzir
