I used to create Java classes in JBuilder with the wizard out of an Oracke 9 db. This worked fine until I imported a new database (same scheme but different data). Now the wizard stops after the first step “Generatin mapping…-” and indeed there are only created the xml mapping files + the ERD and a Class diagram WITHOUT connections between the classes. The ERD has the connections.
What am I doing wrong?
I only have to start the wizard, no? Or do I have to create the diagrams before?
what exactly do you mean by “SDE”?
I open JBuilder then click “Load DBVA PE-JB”.
Then I used to click “Modelling - ORM - WIzards”. Thats it.
The wizard let me choose scheme, tables, etc.
After the wizard was finished I had an ERD, a class diagram + the java classes.
Now the wizard doesn’t create the Class diagramm and the classes anymore.
I even can’t create a simple ERD with “Reverse DB”. I get an empty diagram…
I am glad to know that the problem is solved. If you have time, would you mind letting me know how did you solve the problem? If this is our problem, I will certainly ask our engnieers to fix it up.
