Can i configure orm code generation in a way that only the entity classes are generated? We have our own framework how to implement access to the entities and don´t need all the code generated within the orm directory. I tried to generate with “Mapping only” and use hbm2java to generate the entities from ormmapping/*.erd.xml but this is not as expected a valid hibernate mappings file.
Hi Spilker,
Thanks for your post. It seems that you have raised the same question to our support team, and our Europe team member has response to it already. If I’m right, please check the mail from our Europe member. Thanks!
If you have any inquiry, please feel free to contact us again.
