Help please in generating the code.. i'd got an error
Help…
I can’t generate the code…
ERROR says: No primary key attribute found in class Order.
But i don’t need a primary key in that entity…
I have 2 entity
item_master_file
  • item_code(PK)
  • description
  • qty_stock
order_line
  • item_code(FK)
  • qty
How can i generate the code without setting a primary key in the order_line entity?
Thanks…
Hi jplans,
Thank you for your post. Unfortunately, it is a must to have PK in entity in order to generate database. Sorry about this.
