I need to copy diagrams from a project to another.
Is that possible? How can i do it?
Plase help me …
Nestor
Plase help me …
Nestor
Hi Nestor,
I’m not really entirely sure what you mean. Could you plean explain more?
Currently, you can export the diagram to an image (say JPG or PNG) and then import it to your other program (say MS Word). Alternatively, you could copy the to the system clipboard as an OLE object and paste into MS Word and perform editing inside Word!!
Hope this has more insight to what you want.
Martyn
Hi Martin …
I need to copy diagrams from a VP-UML project to another VP-UML project.
Thank you …
Nestor
Hi Nestor,
A standard copy and paste should do the trick.
Martyn
Hi Nestor,
Which version of VP-UML are you using?
Martyn
Hi Martyn
I am using VP-UMP version 3.1 professional edition (Build 20040224d).
Nestor
Hi Nestor,
That version should be able to do it. Make sure you are not closing the application. Copy the diagram you need, close the project, open the other project and paste it.
It should work
Martyn
really?
For instance. I need copy a use case diagram from a VP-UML to another. I can only copy “within VP-UML” or “copy to system clipboard as image”. But i can’t copy the use case to another VP-UML project.
A standard copy and past don’t do it.
Please help me …
Thanks you!!
Nestor
