How much Visual Paradigm code is generated or specified using Visual Paradigm? Could you give some approximate percentages?
This is a serious question because if you use your own tools to specifiy control and generate your own products then it provides the greatest possible confidence-booster for your customers and salesmen.
If you do not already use your own tools from end to end, then maybe you should, for the above reason.
Of course you did not have your own tools when you started - but you do now! Don’t you?
This post is intended to be seen as in a positive light, I am not criticising, I just want companies offering model-based development to succeed.
Simon A
Apologies if this is the wrong forum…
