- I add a comment in the class specification of an object.
- I run the report writer
How to display the comment i had in the object
Ps: Version Visual Paradigm for UML Entreprise Edition v7.0(Build 20090618)
Hi user,
Thanks for your post. Attached you can find a sample, which is modified from BasicInformation.xml in VPSuite/resources/Report/Default/Class folder, for generating the comments of class. You can refer to this sample to customize the template of Report Writer.
You can also see the details about tags in sample template and the output of comment with the sample template.
Hope this helps. If there is any further inquiry, please feel free to ask.
[quote=LilianWong]Hi user,
Lilian Wong[/quote]
Thanks a lot, it s work fine
Hi user,
You are welcome.
You are welcome.
Lilian Wong[/quote]
And for the comment for the Entity Relationship Diagram, how i proceed ?
Hi user,
Thanks for your post. I’ve forwarded the issue to our engineers to follow-up. If there is any feedback, I’ll come back to you at once.
Hi user,
Sorry for my late response. We fixed to add default template “Comments.xml” so that you can see the template when select ERD on Diagram Navigator in Report Writer.
Please run “VP Suite Update” (inside VPSuite/bin folder) to update your product to build sp1_20090829 for the fix.
Feel free to contact me if there is anything I can help.
Lilian Wong[/quote]
It s work fine.
thanks
I see you do the same change for the others diagrams.
thanks too
Hi user,
You are welcome.
