I successfully installed the smart Development Environment (SDE) for visual studio.
I also developed a small Use case diagram as well. Now …I need to get the related code of that UML diagram.
How Can i get that related code.(for example C# code)
Meanwhile; How to get the Diagram Navigator Pane. It is not visible in my VS-2005 environment.
You cannot generate code from use case diagram. To generate code from UML diagram, please model your application/system with class diagram, and press the Update Code button from the diagram pane to generate code from the diagram.
