Thank you for the quick response and the link. I did see this earlier but was a bit concerned since the UI itself limited it to 2G.
The Java VM has no such limitation per se, but this 2G limit has been on VP for many years based on looking at older versions and discussions on the web.
I will update the VM args and look the process and see if it indeed did use the larger memory space.
I will also add a feature request to allow the UI to allow for larger values.
Thanks again!
