Under the database configuration documents, it mentions that you can select multiple database vendors as long as on is selected as the default. (https://www.visual-paradigm.com/support/documents/vpuserguide/3563/3584/85403_databaseconf.html)
Once this is done, how do you specify which database vendor a table of diagram should use?
I am trying to determine how to handle the following scenario:
I have a product that uses Oracle for its primary database. However, the client applications also use a local SQL Server Express database. Is there a way to correctly document these two schemas within the same VPP? If not, what is the purpose of ever selecting multiple database vendors under database configuration?
I did notice that if I switch the default vendor, then all of the column types automatically convert to an appropriate type for the new default.
Version 13.0, B 20160320eh CE
