I have tried to import an ERWin file (both XML formats) into VP/UML, and, though the diagram itself, and the entities and attributes, come across fine, I don’t see any of the comments on tables or attributes of tables that are in the ERWin diagram. I can’t tell if this is a problem with the ERWin export, or the VP/UML import.
Hi Don,
This problem is fixed. Please download the hotfix at:
http://files3.visual-paradigm.com/200610/Hotfix/5-3-3_sp3_20061026e/vpplatform.jar
I guess you know how to install the hotfix. If not, please refer to:
http://resource.visual-paradigm.com/tips_and_tricks/general/replacing_hot_fix.html
I will post here when a complete release is ready. Have a nice weekend!
Thanks, Jick, but, the shortcut you sent me is pointing to a vpplatform.zip file that has a lot of stuff, but, I can’t find the .jar file in it.
Hi don,
I guess you were downloading with Internet Explorer. I.E. automatically converts the .jar to .zip, therefore, please rename it to .jar manually.
Thanks, Jick… and, I am now using the new version of vpplatform you sent, but, I still see no documentation comments on the columns, or the tables, when I do the import from the ERWin xml file. I know the comments are there, as I opened the xml file directly in ERWin, and can see them…
Hi don,
I am sorry about this. May I have your XML file? I will check this issue again with our engineers. I suggest sending me the XML through email:
jick@visual-paradigm.com
Hi Don,
The problem is fixed. Please download the hotfix again at:
http://files4.visual-paradigm.com/200611/Hotfix/5-3-3_sp3_20061026r/vpplatform.jar
Once again, Jick, you folks do great work… all works fine now. Thanks much for your support
Have a great day!
don
Hi Don,
You are welcome. As I know there will have a complete release later on this today. I will post again when it is out.
Hi Don,
Build 20061111 is now ready. Since you have been asked to use a hotfix, please run the updater inside $vp-suite-install/bin to advance to the latest release.
jick
