I’m using the standard template for generating a word document. I have a list of requirements stored within my requirements grid. These have been split out and attached to various different use cases.
When I am exporting the use case details, is it possible to export these specific requirements also?
Cheers for any help or guidance provided! [/quote]
Figured it out, have to add the requirements indivdually to each Use Case as modal elements.
Figured it out, have to add the requirements indivdually to each Use Case as modal elements. [/quote]
So, its a waste of time to use the add requirements button in the use case details screen? (I’m using Agilian, but it sounds as if the functionality is the same). I just spent hours doing that and now I have to go back and do something else?
I agree, that would take ages. However I have since found out that if you add a requirements diagram per use case, and enter your requirements in there, they are automatically added to the use case. Much more effective way of managing requirements.
