I am very new to UML and am using this program for generating diagrams rather than using it to generate code. I have been able to do everything I need for a Class Model apart from illustrate inheritance between classes. Is this possible?
Inheritance relationships are represented using the “Generalization” connector. If you are using VP-UML Standard Edition or above, you can perform “Instant Reverse” on the source code or executable, and then generate diagrams using the “Form Diagram” facility. All the models and relationships will be created automatically on the diagrams.
