I get a nice little error here when trying to input into the database.
Just testing some stuff to make sure I did it right.
Either I didnt, or I have found a bug.
here is the error produced.
INSERT INTO temp_list (name, ) VALUES (‘hahah’, );
Fatal error: Uncaught exception ‘epExceptionDbAdodb’ with message 'Cannot execute query: mysql error: [1064: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘) VALUES (‘hahah’, )’ at line 1] in EXECUTE(“INSERT INTO temp_list (name, ) VALUES (‘hahah’, );”) ’ in /var/www/vhosts/myarcworld.com/httpdocs/arcg2/lib/phporm/src/db/epDbAdodb.php:194 Stack trace: #0 /var/www/vhosts/myarcworld.com/httpdocs/arcg2/lib/phporm/src/db/epDb.php(317): epDbAdodb->_execute(‘INSERT INTO tem…’) #1 /var/www/vhosts/myarcworld.com/httpdocs/arcg2/lib/phporm/src/db/epDbObject.php(2283): epDb->execute(‘INSERT INTO tem…’) #2 /var/www/vhosts/myarcworld.com/httpdocs/arcg2/lib/phporm/src/db/epDbObject.php(1548): epDbObject->_execute(‘INSERT INTO tem…’) #3 /var/www/vhosts/myarcworld.com/httpdocs/arcg2/lib/phporm/src/runtime/epManager.php(992): epDbObject->insert(Object(epClassMap), Object(epObjectWrapper)) #4 /var/www/vhosts/myarcworld.com/httpdocs/arcg2/lib/phpor in /var/www/vhosts/myarcworld.com/httpdocs/arcg2/lib/phporm/src/db/epDbAdodb.php on line 194
Any idea?
