Installation failed with wrong path to JBuilder2005. All permissions are set. Did some Body have any idea.
With regards
Stephan
With regards
Stephan
Dear Stephan,
Thank you for your message and I’m sorry for any inconvenience this problem caused you. I’ve forwarded your problem to our engineers to follow-up. Once there are any feedbacks, I’ll comeback to you immediately. If you have any further questions, please feel free to contact us again.
Rain
Dear Stephan,
Our engineers had tested installing and running SDE & DBVA on JBuilder 2005 and didn’t found any problem. Please make sure you have select the correct JBuilder path when installing the SDE
/Developer/Applications/Borland/JBuilder2005/JBuilder.framework
(assume you are install the JBuilder to the default location).
If the problem still persists after installing the software with correct path, please let me know!
Rain
Thats the solution. Thank for quick response
