I got a java error during installing VP Community. Could anyone give me an idea to solve it?
Unpacking JRE ...
Preparing JRE ...
Starting Installer ...
Locking assertion failure. Backtrace:
#0 /usr/lib/libxcb-xlib.so.0 [0xb75bb858]
#1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_unlock+0x2a) [0xb75bb91a]
#2 /usr/lib/libX11.so.6(_XReply+0xfd) [0xa9f2facd]
#3 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.7261.dir/jre/lib/i386/xawt/libmawt.so [0xaa01ed7e]
#4 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.7261.dir/jre/lib/i386/xawt/libmawt.so [0xaa008d47]
#5 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.7261.dir/jre/lib/i386/xawt/libmawt.so [0xaa008ec3]
#6 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.7261.dir/jre/lib/i386/xawt/libmawt.so(Java_sun_awt_X11GraphicsEnvironment_initDisplay+0x26) [0xaa009106]
#7 [0xb29d4bfa]
#8 [0xb29ceb3b]
#9 [0xb29ceb3b]
#10 [0xb29cc219]
#11 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.7261.dir/jre/lib/i386/client/libjvm.so [0xb776619c]
#12 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.7261.dir/jre/lib/i386/client/libjvm.so [0xb787ab38]
#13 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.7261.dir/jre/lib/i386/client/libjvm.so [0xb7765fcf]
#14 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.7261.dir/jre/lib/i386/client/libjvm.so(JVM_DoPrivileged+0x32d) [0xb77c3a7d]
#15 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.7261.dir/jre/lib/i386/libjava.so(Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedAction_2+0x3d) [0xb755c30d]
#16 [0xb29d44ab]
#17 [0xb29cea64]
#18 [0xb29cc219]
#19 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.7261.dir/jre/lib/i386/client/libjvm.so [0xb776619c]
java: xcb_xlib.c:82: xcb_xlib_unlock: Assertion `c->xlib.lock' failed.
./VP_Suite_Linux_4_1_20091009.sh: line 327: 7353 Aborted "$app_java_home/bin/java" -Dinstall4j.jvmDir="$app_java_home" -Dexe4j.moduleName="$prg_dir/$progname" -Dexe4j.totalDataLength=149133212 -Dsun.java2d.noddraw=true $INSTALL4J_ADD_VM_PARAMS -classpath "$local_classpath" com.install4j.runtime.Launcher launch com.install4j.runtime.installer.Installer false false "" "" false true false "" true true 0 0 "" 20 20 "Arial" "0,0,0" 8 500 "version 4.1" 20 40 "Arial" "0,0,0" 8 500 -1 "$@"
Hi user,
Thank you for your post. The problem should relate to JRE. Could you please try
export LIBXCB_ALLOW_SLOPPY_LOCK=1
or try using JDK 1.6 and see if you can install the software?
I look forward to hearing your response.
Thank you for your reply!
Unfortunately, it’s still the same. Here I listed my env vars for your reference.
Any other info may help?
/home/user/Downloads> ./VP_Suite_Linux_4_1_20091009.sh
Unpacking JRE ...
Preparing JRE ...
#0 /usr/lib/libxcb-xlib.so.0 [0xb7648858]
#1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_unlock+0x2a) [0xb764891a]
#2 /usr/lib/libX11.so.6(_XReply+0xfd) [0xa9fbfacd]
#3 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.16357.dir/jre/lib/i386/xawt/libmawt.so [0xaa0aed7e]
#4 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.16357.dir/jre/lib/i386/xawt/libmawt.so [0xaa098d47]
#5 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.16357.dir/jre/lib/i386/xawt/libmawt.so [0xaa098ec3]
#6 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.16357.dir/jre/lib/i386/xawt/libmawt.so(Java_sun_awt_X11GraphicsEnvironment_initDisplay+0x26) [0xaa099106]
#7 [0xb2a61bfa]
#8 [0xb2a5bb3b]
#9 [0xb2a5bb3b]
#10 [0xb2a59219]
#11 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.16357.dir/jre/lib/i386/client/libjvm.so [0xb77f319c]
#12 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.16357.dir/jre/lib/i386/client/libjvm.so [0xb7907b38]
#13 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.16357.dir/jre/lib/i386/client/libjvm.so [0xb77f2fcf]
#14 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.16357.dir/jre/lib/i386/client/libjvm.so(JVM_DoPrivileged+0x32d) [0xb7850a7d]
#15 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.16357.dir/jre/lib/i386/libjava.so(Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedAction_2+0x3d) [0xb75e930d]
#16 [0xb2a614ab]
#17 [0xb2a5ba64]
#18 [0xb2a59219]
#19 /home/user/Downloads/VP_Suite_Linux_4_1_20091009.sh.16357.dir/jre/lib/i386/client/libjvm.so [0xb77f319c]
./VP_Suite_Linux_4_1_20091009.sh: line 327: 16652 Aborted "$app_java_home/bin/java" -Dinstall4j.jvmDir="$app_java_home" -Dexe4j.moduleName="$prg_dir/$progname" -Dexe4j.totalDataLength=149133212 -Dsun.java2d.noddraw=true $INSTALL4J_ADD_VM_PARAMS -classpath "$local_classpath" com.install4j.runtime.Launcher launch com.install4j.runtime.installer.Installer false false "" "" false true false "" true true 0 0 "" 20 20 "Arial" "0,0,0" 8 500 "version 4.1" 20 40 "Arial" "0,0,0" 8 500 -1 "$@"
/home/user/Downloads> java -version
java version "1.6.0_16"
Java(TM) SE Runtime Environment (build 1.6.0_16-b01)
Java HotSpot(TM) Client VM (build 14.2-b01, mixed mode, sharing)
/home/user/Downloads> set | grep ^[A-Z].*\=
BASH=/bin/bash
BASH_ARGC=()
BASH_ARGV=()
BASH_COMPLETION=/etc/bash_completion
BASH_COMPLETION_DIR=/etc/bash_completion.d
BASH_LINENO=()
BASH_SOURCE=()
BASH_VERSINFO=([0]="3" [1]="1" [2]="17" [3]="1" [4]="release" [5]="i486-pc-linux-gnu")
BASH_VERSION='3.1.17(1)-release'
COLORTERM=
COLUMNS=80
DIRSTACK=()
DISPLAY=:0
EUID=1000
GROUPS=()
GTK_IM_MODULE=gcin
HISTCONTROL=ignoredups
HISTFILE=/home/user/.bash_history
HISTFILESIZE=500
HISTSIZE=500
HOME=/home/user
HOSTNAME=asus-1249270781
HOSTTYPE=i486
IFS=$' \t\n'
JAVA_HOME=/home/user/jdk1.6.0_16
KONSOLE_DCOP='DCOPRef(konsole-13373,konsole)'
KONSOLE_DCOP_SESSION='DCOPRef(konsole-13373,session-1)'
LANG=en_US.UTF-8
LC_ALL=en_US.UTF-8
LESSCLOSE='/usr/bin/lesspipe %s %s'
LESSOPEN='| /usr/bin/lesspipe %s'
LINES=24
LOGNAME=user
LS_COLORS='no=00:fi=00:di=01;34:ln=01;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.gz=01;31:*.bz2=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.avi=01;35:*.fli=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.flac=01;35:*.mp3=01;35:*.mpc=01;35:*.ogg=01;35:*.wav=01;35:'
MACHTYPE=i486-pc-linux-gnu
MAIL=/var/mail/user
MAILCHECK=60
OLDPWD=/home/user
OPTERR=1
OPTIND=1
OSTYPE=linux-gnu
PATH=/home/user/jdk1.6.0_16/bin:/usr/local/bin:/usr/bin:/bin:/usr/games
PIPESTATUS=([0]="0")
PPID=13373
PROMPT_COMMAND='echo -ne "\033]0;${USER}@${HOSTNAME}\007"'
PS1='${debian_chroot:+($debian_chroot)}\[\033[1;32m\]$PWD\[\033[1;00m\]> '
PS2='> '
PS4='+ '
PWD=/home/user/Downloads
QT_IM_MODULE=gcin
SHELL=/bin/bash
SHELLOPTS=braceexpand:emacs:hashall:histexpand:interactive-comments:monitor
SHLVL=7
TERM=xterm
UID=1000
USER=user
WINDOWID=52428807
XAUTHORITY=/home/user/.Xauthority
XIM_PROGRAM=/usr/bin/gcin
XMODIFIERS=@im=gcin
Hi Lohengrin,
Thanks for replying. Could you please download no-install version from our website ( http://www.visual-paradigm.com/download/ ) and follow the steps to use JRE 1.6 and see if the problem can be solved:
- extract downloaded VP Suite no-install version
- rename bundled “jre” directory to something else
- download latest JRE 1.6 from http://java.sun.com and install it
- copy the “jre” folder of installed latest JRE 1.6 to VP_Suite directory (make sure it’s named “jre”)
- run VP_Suite/bin/VP_Suite to try installation
Look forward to hearing your response.
Can proceed the installation UI now. Thank you!
Hi Lohengrin,
You are welcome. Please feel free to have another post if you need any help again.
