just wondering if i could get some help… I have downloaded and installed the CE with the key… everything works fine.
When I try to startup run_vpuml.jar it just hangs on the splash screen. I am run osx 10.39…
I have read through the forum and noticed that others have had similar problems, so i have attached my log file. If some could take a quick look it would be great.
Thank you for your post. We will fix the problem and get back to you. If possible, you can upgrade your JDK to version 1.5. This will solve the problem.
Run $vp-suite-install-dir/bin/VP Suite to install the patch
Restart the application
Note:
How are you? I would like to notify you that a newer release of VP Suite is ready. It is now safe to run the product updater to advance to the latest release. In fact, you are suggested to do so because you are using a patch. Please feel free to let me know if there are any questions.
