Installation Problem
I download “vpumlce_20030520.exe” and try to install. But boxup “Please select another location to extract the installer to:” so I choose another location but the the message still boxup and non-stop always ask me to select another location.
So I ignore it and click “vpumlce_20030207.exe” from the extracting folder but appear " Fatal Application Error" boxup, said"Invocation of this Java Application has caused an Invocation TargetException. This application will now exit.(LAX)."
I click the details, inside the details said that:
ava.lang.NullPointerException
at java.io.RandomAccessFile.open(Native Method)
at java.io.RandomAccessFile.<init>(Unknown Source)
at ZeroGv.<init>(Unknown Source)
at ZeroGb.d(Unknown Source)
at ZeroGb.v(Unknown Source)
at com.zerog.ia.installer.actions.MakeExecutable.l(Unknown Source)
at com.zerog.ia.installer.actions.MakeExecutable.getSizeSelf(Unknown Source)
at com.zerog.ia.installer.actions.InstallUninstaller.getSizeSelf(Unknown Source)
at com.zerog.ia.installer.InstallPiece.getSize(Unknown Source)
at com.zerog.util.CheckDiskSpaceUtil.b(Unknown Source)
at com.zerog.ia.installer.actions.InstallSummary.getMessageText(Unknown Source)
at com.zerog.ia.installer.actions.InstallSummary.e(Unknown Source)
at com.zerog.ia.installer.installpanels.LicenseAgrActionPanel.f(Unknown Source)
at com.zerog.ia.installer.installpanels.LicenseAgrActionPanel.e(Unknown Source)
at com.zerog.ia.installer.installpanels.LicenseAgrActionPanel.a(Unknown Source)
at com.zerog.ia.installer.installpanels.InstallSummaryPanel.a(Unknown Source)
at com.zerog.ia.installer.Main.d(Unknown Source)
at com.zerog.ia.installer.Main.b(Unknown Source)
at com.zerog.ia.installer.Main.main(Unknown Source)
at com.zerog.lax.LAX.launch(Unknown Source)
at com.zerog.lax.LAX.main(Unknown Source)
I’m using WindowsXP PRO. Please help me !
It seems like you don’t have enough space to run the setup !
Try to change folder !
I downloaded VP for UML Community Edition version 2.2 ( Build 20030808e)and set up program - no problem. I obtained the activation key file as an Email Zip file attachment. However the zip file will not open - the reason
" UnZip error : Bad CRC ". Can anyone help ?
Larry,
An error in transmission might have occured when you downloaded the Key as a zip attachement. Try and dowload the key again from your e-mail.
Hope that helps.
Martyn
Hi
I have the same problem like djlah on 23.07. Everytime I try to install the program I get the message I should choose another location. BUT THERE IS ENOUGH SPACE AND MEMORY!!! I HAVE 6 GB OF FREE SPACE, THIS SHOULD BE REALLY ENOUGH TO UNPACK THE INSTALLER! WHAT IS THE PROBLEM?
Kind regards
Sandra
Hi Sandra,
This problem is caused by InstallAnywhere, I suggest try downloading the file again. Alternatively, download the no_install variant of VP-UML.
Martyn.
