I try to instant reverse from my java source (version 5.0). But VP says that it is “unable to parse”. I look my java file and it seems that VP does not undestand the java tags like “@Override”. Have you a solution ?
thanks in advance.
thanks in advance.
Hi user,
Sorry for the problem. Could you provide me with code sample to repeat the problem? Thank you in advance.
Best Regards,
Ok, for example, I have two classes in two files.
This is the first class :
public abstract class AbstractClass {
public abstract void print();
and the second :
public class ConcreteClass extends AbstractClass {
@Override
public void print() {
System.out.println("hello !");
In VP, when I do “Instant Reverve” with “Java Source” on my source folder, I have the message “src\ConcreteClass.java: Unable to parse. (Line=2)”. The reason is the tag @Override because when I remove it, VP can instant reverse. But in my real project, I don’t wan’t to remove this tags.
Hi user,
Thank you for your post. I can reverse your code without any problem. May I know which build you are using? Could you post the vp.log file here for us to identify the problem? You can locate the log file at $vp-suite-install-dir/bin/vp.log
I look forawrd to hearing from you.
Best Regards,
ok, I attach my log file. I don’t think it can help you because it’is empty. I also make a screenshot.
vp.log
Hi user,
The log shows that you are using Service Pack 1 with build number 20060417, which is a pretty old release. The latest release is Service Pack 2 build 20060527. In fact, the whole Instant Reverse engine is enhanced in Service Pack 2. Therefore, please download Service Pack 2 and try the Instant Reverse again. I am sure that the problem was fixed.
Best Regards,
ok
thanks for your time
You are welcome.
Please feel free to post again if there are any other questions.
