I would like to know if some of you had this problem :
Reason :
Error in parsing source file.
Please make sure there is executable permission to all files under C:\Program Files\VP Suite 4.0\visualstudio_2008\sde\vp_windows.
input buffer overflow, can’t enlarge buffer because scanner uses REJECT
I have it everytime when i try to reverse OgreMain source code.
Thank you in advance.
Hi user,
Thanks for your post. Refer to question 13 in Doxygen’s frequent asked questions ( http://www.stack.nl/~dimitri/doxygen/faq.html ):
- Help! I get the cryptic message “input buffer overflow, can’t enlarge buffer because scanner uses REJECT”
This error happens when doxygen’s lexical scanner has a rule that matches more than 256K of input characters in one go. I’ve seen this happening on a very large generated file (>256K lines), where the built-in preprocessor converted it into an empty file (with >256K of newlines). Another case where this might happen is if you have lines in your code with more than 256K characters.
If you have run into such a case and want me to fix it, you should send me a code fragment that triggers the message. To work around the problem, put some line-breaks into your file, split it up into smaller parts, or exclude it from the input using EXCLUDE.
Maybe you will find the stated workaround useful for solving your problem.
