When I try to instant reverse C++ code I am getting the error:
“Instant Reverse Unsuccessful. Reason: Error occurred in preparation.”
I have been able to successfully instant reverse Java source. Why is it having trouble with C++? Any clues, anyone?
January 3, 2006, 9:02am
2
Dear Anonymous,
Could you please send me the following items for checking the problem?
vp.log file (under %VP-Suite_HOME%/bin )
The C++ source you attemped to reverse
You can reach me at jick@visual-paradigm.com
Perry
May 12, 2006, 10:05am
3
I have this same problem. Can I send in my files too?
Thank you,
Perry Smith
May 12, 2006, 10:10am
4
Hi Perry,
Sure you can. I look forward to receiving your email.
Best Regards,
hez
March 16, 2007, 5:26am
5
I have encountered the same issue. It looks like its a problem with launching some other shell/command.
From the log file:
[error] java.io.IOException: /Applications/VP Suite 3.0/bin/vp_windows/mac_doxygen: cannot execute
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.(UNIXProcess.java:52)
at java.lang.ProcessImpl.start(ProcessImpl.java:91)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:451)
at java.lang.Runtime.exec(Runtime.java:591)
at v.ztg.i(:195)
at v.ztg.i(:145)
at v.ztg.i(:137)
at v.imef.i(:280)
at v.imef.i(:194)
at v.afh.d(:63)
at v.ibnf.run(:15)
March 16, 2007, 10:23am
6
Hi hez,
Please give ‘execute’ permission to this file:
$vp-suite-install-dir/bin/vp_windows/mac_doxygen
After that, the problem should be solved. If the problem persists,
please let me know.
hez
March 16, 2007, 11:17am
7
That seems to have fixed it.
But now when I run through the instant reversal I don’t get any kind of out put. It says successful but nothing shows up in my current project.
Nothing in the log file.
Any suggestions?
March 16, 2007, 12:02pm
8
hello hez,
Do you see any models appear in the Model Tree? If not, please send me the vp.log file produced under the bin folder of $vp-suite-install-dir.
hez
March 16, 2007, 12:36pm
9
Nothing appears in the model tree at all and as far as I can tell nothing shows up in the log.
Log:
hez@hez /Applications/VP Suite 3.0 $ cat bin/vp.log
[Thu Mar 15 21:33:58 PDT 2007] [message] [Thu Mar 15 21:33:58 PDT 2007]: Start Agilian Standard Edition [AG SE]: 1.0 (sp1_20070310)
[Thu Mar 15 21:34:20 PDT 2007] [message] [Thu Mar 15 21:34:20 PDT 2007]: Start Visual Paradigm for UML Enterprise Edition [VP-UML EE]: 6.0 (sp1_20070310)
March 16, 2007, 2:19pm
10
Hi hez,
Is it possible to send me your code for reproducing the problem? If you mind posting here, you may send to my email address:
kashej
March 19, 2007, 8:20pm
11
I have the same problem. I have given the execution permission recursively to all files in the installation folder of VP, but it could not help.
March 20, 2007, 9:22am
12
Hello kashej,
Could you send me your code and log file for reproducing the problem? You can find the vp.log file inside $vp-suite-install-dir/bin
kashej
March 20, 2007, 11:06pm
13
I have given recursively read, write and execution access to all files in the install directory of VP.
If I :
change to the /install-directory/bin folder
start eclipse
make “instant reverse” then it functions (instant reverse successful)
But if I start eclipse from some other directory, sde cannot find doxygen.
March 21, 2007, 10:14am
14
Dear kashej,
I recommend you start the Eclipse first, and then start SDE from within Eclipse. This should solve the problem.
