Hi!
I have a following problem: after updating my Intellij installation from 12 to 13 I can’t use IDEA<–>VP-UML integration. Cliking on [Tools]->[Load VP-UML PE] I get an exception:
null
at v.cgos.a(:85)
at v.cgpl.b(:262)
at v.cgpl.a(:202)
at v.cgzi.a(:48)
at v.cgcq.a(:43)
at v.cgcq.actionPerformed(:29)
at com.intellij.openapi.actionSystem.ex.ActionUtil.performActionDumbAware(ActionUtil.java:162)
at com.intellij.openapi.actionSystem.impl.ActionMenuItem$ActionTransmitter$1.run(ActionMenuItem.java:261)
at com.intellij.openapi.wm.impl.FocusManagerImpl.runOnOwnContext(FocusManagerImpl.java:916)
at com.intellij.openapi.wm.impl.IdeFocusManagerImpl.runOnOwnContext(IdeFocusManagerImpl.java:124)
at com.intellij.openapi.actionSystem.impl.ActionMenuItem$ActionTransmitter.actionPerformed(ActionMenuItem.java:231)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at com.intellij.openapi.actionSystem.impl.ActionMenuItem.fireActionPerformed(ActionMenuItem.java:104)
at com.intellij.ui.plaf.beg.BegMenuItemUI.a(BegMenuItemUI.java:512)
at com.intellij.ui.plaf.beg.BegMenuItemUI.access$300(BegMenuItemUI.java:44)
at com.intellij.ui.plaf.beg.BegMenuItemUI$MyMouseInputHandler.mouseReleased(BegMenuItemUI.java:532)
at java.awt.Component.processMouseEvent(Component.java:6505)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3320)
at java.awt.Component.processEvent(Component.java:6270)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:708)
at java.awt.EventQueue$4.run(EventQueue.java:706)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:705)
at com.intellij.ide.IdeEventQueue.e(IdeEventQueue.java:696)
at com.intellij.ide.IdeEventQueue._dispatchEvent(IdeEventQueue.java:520)
at com.intellij.ide.IdeEventQueue.dispatchEvent(IdeEventQueue.java:335)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
I am using Windows 8.1 and have 64-bit operating system. I installed 32-bit VP-UML version, so that it maches my x86 Intellij IDE.
If anyone knows how to deal with that problem - please help!
Same Error…
window7, 64bit, Intellij13, 64bit VP-UML
null
at v.cgqb.a(:85)
at v.cgqu.b(:262)
at v.cgqu.a(:202)
at v.char.a(:48)
at v.cgdz.a(:43)
at v.cgdz.actionPerformed(:29)
at com.intellij.ide.IdeEventQueue.e(IdeEventQueue.java:697)
We found that the executable of IntelliJ changed since v13 and causing the integration can’t be run. Can you try launch IntelliJ IDEA with the idea.bat (inside its bin folder) and see is the integration works?
I can confirm I have the same issue with IntelliJ Ultimate 13.1.3 on Windows 8.1 Pro x64, and using idea.bat does resolve the issue but leaves the command window open until you close idea or if you close the command window it terminates the idea process.
Is there a cleaner solution that works with the original idea.exe launcher? If the issue is with JetBrains, has an issue been reported to them?
