i am using VP-UML CE for a while now and i am very happy with it. There’s just one thing: It uses a huge amount of memory! java.exe is using 70MB at startup and about 80+ when loaded a project!
is this normal or just a bug on my pc?
Belthazor
Belthazor
Belthazor,
70MB at startup seems to be a little bit high. What OS are you using and how much RAM does your computer have?
I have tested VP-UML CE on a P3-1000 with 256MB RAM, fresh install of Windows XP and it uses a little over 45MB on startup.
Martyn
You might want to look at your initial Java settings. It could be that all of your Java programs may be starting with this default memory size. Otherwise, “VP-UML.exe” is setting that initial minimum.martyn wrote:
