In the DB-VA 3.1sp1 (VP_Suite_Windows_3_1_sp1_20071012) I am evaluating, I have found these small bugs:
If the namespace has mixed case, the code generated has errors, because sometimes the upper case letters are conserved, but sometimes they aren’t (the namespace is “lower cased”) -> So you are FORCED to use always lower case for the namespace. Maybe not a big issue, but maybe also an easy fix to implement in your software
If the namespace chain is the same of a part of another namespace, the generated code fails (well, at least in C#) because the compiler does not find the right namespace -> Fixed easily putting “global::” in front of a declaration. Example:
The problem caused by mixed cases should had been fixed for several builds. Could you provide me with some steps or simpler, the project file for producing the problem? Thank you in advance!
Many thanks!! Your team is very FAST with this small bugs, congratulations!!
Well, you are right :oops: This bug has been fixed. Sorry, I was testing with an “old build” (20071012, I think) and I did not re-test this with the new version before posting the topic in the forum.
