I’m getting ready to install the VP Server software. I need to confirm which ports it uses. Does this use Tomcat? The plan is to run from a server that already has several instances of Tomcat on it so I’d be doing port steering.
Hello ComputerHabit,
If you are install the VP Server using our installation package it will then have port 1999 as default. You can follow the article below to modify our default port.
And if you are deploy it into your own Tomcat then it simply follow the port your Tomcat running on.
Rain Wong
