actually, we had a problem with “insertable” and “updatable” properties annotation.
Here is the following code which pose problem: “@JoinColumns({ @JoinColumn(name=“DispositionActionsID”, referencedColumnName=“ID”, insertable=false, updatable=false) })”
So the question is, why those two properties are always set to false? As a consequence we cannot add records to our database.
Is it possible to configure them?
Thanks for your post. This is because the column “DispositionActionsID” is referencing the column “ID” of other table, which the value cannot be inserted or updated manually (as they are PK of other table). If there is any further inquiry, please do not hesitate to ask.
Ok for your explanations, let’s take a concrete example. Indeed, the problem is the following: DispositionsActions is a table which is referenced in RecordClassIGP table. As a matter of fact, when I try to add a record to RecordClassIGP table, I can’t whereas DispositionsAction table contains records. However, if “insertable” is set to true then I can do my insertion.
So I’d like to insert a row in RecordClassIGP in referencing a specific record of DispositionsActions table.
Why I can’t do it?
